BB Heater hose routing?
The intake and water pump fittings you're referring to should connect to the heater core back on the passenger-side of the firewall, right?
The hose from the intake goes into the expansion tank - then from the expansion tank into the heater core.
The hose on the water pump goes directly to the heater core.
I'm nearly 99% sure - I will check when I get home from work and post again if I'm incorrect.
Bill
Bill
the intake went to the heater core through the valve
the pump went to the front of tank
the back of tank went to the heater core
Mike229 is correct .....
I checked my car just 5 minutes ago and the routing is as Mike229 says.
On my car, the only diference is 72' cars did not have a cut-off valve for the heater core. My hose from the intake goes directly to the heater core.
Thats why I said I'm 99% sure..
becuase there is always a chance of being wrong...Bill
