Engine rebuild
Old Jul 7, 2005 | 12:19 PM
nvvetgirl's Avatar
nvvetgirl
Default Engine rebuild
I have a 75 L-48. I want to put in a much higher horsepower engine. Can anyone tell me if the 1975 engine block is worth rebuilding into a better powerplant or is a more recent 350 engine block technologically better or all standard 350 blocks equal?
Old Jul 7, 2005 | 12:26 PM
lars's Avatar
lars
Any 1st generation 350 block can be built to any level of performance you want. If your current block is the original one, you may want to consider leaving it intact and storing it to retain the originality and building your "play" motor from another core. 350 blocks, cranks and components parts are cheap and easy to find, so you can build a complete engine while keeping your car running during the process.
Old Jul 7, 2005 | 01:29 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
nvvetgirl,
I was in your same shoes roughly 4 months ago. Rather then use another block, I decided to use my original block for the build, that way I'd keep it in the car if I ever wanted to sell it. The engine needed a rebuild anyway, and the block was perfectly good, so I figured, why do I need another piece of cast iron sitting in the corner that isn't working.
A couple of things about getting the original block rebuilt...always make sure that the engine pad (passenger side front of the block) has the correct numbers stamped in that match your engine...and make darn sure that the machinists do not deck the block to the point that those stampings are removed...that is your sure bet for authenticity (mostly).
Good luck with your rebuild...look around, you'll get a lot of advice on what you should do.
trw
Old Jul 7, 2005 | 01:43 PM
Solid LT1's Avatar
Solid LT1
The Cast Iron in Chevy blocks untill about 1977-78 is pretty good. The L-48 won't have a "race worthy" 010/020 block like a L-82 Vette but can still be built to 420-450HP levels with good reliability (plenty for a street motor!)
Old Jul 7, 2005 | 08:07 PM
marshrat99's Avatar
marshrat99
About 3 yrs ago I was in the same position. Although my 79 "smog" L82 was a great running engine, it just didn't have the performance you'd like to have in a C3. I believe the 79 L82 as quoted as only having 220HP and I'd believe it. Anyway, I pulled the engine to save just in case someone, sometime wanted the numbers matching engine. I found a nice 350 4bolt block out of a 85 Suburban that had spun the bearings for $50. I tore down the engine to the bare block and had a machinst clean it and magnaflux to check for cracks. The block was OK. Next I got out the Summit, Jeggs and SDPC mags and bought EVERTHING except the block: cam, bearings, rotating assembly, intake, oil pan, oil pump, etc. I had the machinst bore the cylinders to 30over and match the pistons. I did everything else and had to buy all specialty tools to "blue print" the engine. I ended up with about $5,500 in the completed engine but had a great time learning and a few brewsky's along the way. I've now got about 7K miles on the new engine and have had no problems. According to my CR, heads and cam specs, I should have about 350+ HP. I can really feel the difference.
If you're not mechanically inclined, you might want to consider going the GM crate motor route.
Old Jul 7, 2005 | 09:20 PM
page62's Avatar
page62
Personally, I wouldn't worry about keeping the '75 L48 "numbers matching" block intact. With 165hp stock, it represented a low point in Corvette history. Rebuild that sucker into a monster!!!
Old Jul 7, 2005 | 09:23 PM
glen242's Avatar
glen242
My original '76 L-48 has/had a 10/20 block.
To Engine rebuild
