idle problem
Old Jul 7, 2005 | 04:33 PM
toocool80's Avatar
toocool80
Default idle problem
can anyone tell me why my vette idles at 1100 rpms in park and then drops to 400 rpms when put in gear?
Old Jul 7, 2005 | 04:54 PM
Brettmc's Avatar
Brettmc
not adjusted right...prolly a combination of timing and carb out of whack.
My brother just happened to mention last year that his 65 mustang(302, auto, holley 650 dp, comp 268) would die in drive. He said he had to feather the throttle at a stop or knock it up into neutral. I played around with his timing and adjusted his carb and that problem disappeared. Your prolly in the same situation.
Brett
Old Jul 7, 2005 | 06:32 PM
72CoupeORG(smc)'s Avatar
72CoupeORG(smc)
put in a stick, no issue
Old Jul 8, 2005 | 01:36 PM
iNdigo's Avatar
iNdigo
That's not a realistic solution to the problem. You're suggesting he spend $4500 on a new transmission and clutch assembly when really he just needs to spend 10 minutes adjusting his air/fuel/spark.
toocool... check out www.corvettefaq.com and follow basic procedures for tuning. come back here if you have questions.
cheers
the blonde weasel
Old Jul 8, 2005 | 02:07 PM
lars's Avatar
lars
It's a timing problem. You have a vacuum advance control unit that is not pulling in its full vacuum range at the amount of vacuum you're getting in "drive." When you're in neutral, you're getting 16-18 degrees of vacuum advance, and when you drop it in drive you're losing timing from the change in vacuum. You can do one of 2 things:
Switch the vacuum advance from manifold vacuum to ported vacuum ("T" it into the EGR vacuum hose). This will eliminate any vacuum advance at idle and will stabilize your timing between neutral and drive. If you do this, make sure you're runing at least 16-18 degrees of initial timing.
Install a VC 1862 vacuum advance control unit and run anifold vacuum to it. This unit will hold the full vacuum advance in even at very poor manifold vacuum and will give you stable timing in "drive."
Old Jul 8, 2005 | 07:23 PM
rcread's Avatar
rcread
I'm voting for the stick solution. Maybe we should start a poll.
Old Jul 8, 2005 | 07:47 PM
toocool80's Avatar
toocool80
The stick solution would be nice but not right now. Just want it to run right, but thanks for all of the advice I should get it done this weekend.
Old Jul 8, 2005 | 08:24 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
listen to Lars...He Da Sheet!
Old Jul 8, 2005 | 10:45 PM
toocool80's Avatar
toocool80
just printed off his directions gonna try it out tomorrow
To idle problem
