Water pump about to explode...
Drain the radiator (you might as well, most of it will come out anyway.)
Use this time to put on new hoses, good precaustionary. New thermostat too if you've got the time (plus they're cheap.)
Loosen belts ( ps and alt, maybe a/c too, I'm not sure since I have a non-a/c car)
remove nuts holding fan cluctch on (four of them) and remove the pulley on WP. You many have to pull fan shroud off, depends on space, but I wouldn't if you don't have too. Pull the four bolts holding the WP on, and remove wp. Remove 4 studs out of WP pulley, you'll need them for the new one. Make sure you take WP with you to parts store, as not just any wp will fit because its a SBC.
Paint the new wp sbc orange and reinstall, reverse of taking it off.
Prob a 2-3 hour job, depending on rust and beer consumption. good luck.
trw
Heater hose fitting looks to be frozen solid, so I'll try to find one tomorrow.Quick question: do I need any kind of sealant on the plugs and such? There's a plug that goes into the top of the water pump and a fitting for the heater hose, so I'm not sure if they're self sealing or if I need something on them.
I've used teflon tape on those, or if you can find it the liquid teflon in a little applicator bottle works very well.
trw
I'm not entirely sure what you are talking about.
trw
Make sure your fan clutch seems normal.
Use a good silite (RTV, whatever) for sealant. I use the grey "ultra" stuff on aluminum, the black or orange or blue on other stuff (it's just cosmetic.) Be sure to use some of it on all four bolts to the pump as well as the gaskets.
As always, wire wheel clean the bolt threads and replace them if they are damaged in any way. These bolts bear some stress - resist the temptation to switch them for low strength ordinary hardware store SS ones if any do need replacement.
I agree that the upper and lower radiator hoses should be replaced, along with a known temperature thermostat. And as long as you have the water pump belts off, that would be a good time to replace those as well.
If the fan is out of the car, now would be a good time to clean it, and respray it, or touch it up.
And thats why 2-3 hour jobs somehow turn into 2 - 3 jobs.
kdf
Edit: it's the thing between the plug and the gaskets
I'm trying to get my car up and running again asap, so I'm trying not to catch the while-im-at-it-itis.
Off to the parts store for RTV, I don't have any here.
Could be some sort of sleeve thing for the alternator upper bracket spacer - but you said it was solid, not a tube....
Could be something to line up spacers for the fan - all mine have been solid.
Could be the missing second bullet from the JFK SO-CALLED "assasination" which was REALLY an elaborate SUICIDE!!!
(I didn't say they were GOOD ideas....)
time!!
