float leak causing flooding?
Old Jul 10, 2005 | 09:37 AM
big69's Avatar
big69
Default float leak causing flooding?
If I wait 5 minutes after shutting down the motor and then try to restart, it is flooded.
Fuel must be leaking somewhere out of the carb into the motor while it sets. I'm running a Elelbrock Performer carb. Where should I be looking for the leak and how far do I need to take it apart to fix it. Thanks for any help!
Old Jul 10, 2005 | 09:44 AM
fast idle's Avatar
fast idle
if the carb is leaking at the top it may be needle valves, down lower it could be the base plate or the mtering block.
Old Jul 10, 2005 | 09:59 AM
big69's Avatar
big69
Would it work to remove the carb, pour fuel into the vent, wait a few minutes to see if it leaks on through and then trying to figure where the leak is located?
Old Jul 10, 2005 | 11:48 AM
Techno's Avatar
Techno
It sounds like the fuel has boiled out of the bowl not leaked.
This happens when engine is hot and short interval before restart.
Engine still needs some cranking to restart like 15 minutes later but don't have to hold pedal to floor- not flooded. Both times the bowl is still empty though and engine has to be cranked just to fill that.
I had that problem and got an electric pump to refill the bowl without cranking the engine.
Start engine when cold. Before it ever gets close to warm shut it off and do your 5 minute restart. If it leaks it won't restart. If it don't leak its the boiling problem.
Old Jul 10, 2005 | 11:49 AM
fast idle's Avatar
fast idle
right now i am diagnosing a leak on mine ,its a holley, i have an 8 inch bake pan with the carb sitting on it ,the fuel line only hooked up , i can wind it over to build pressure, try the throttle,my carb buddy used this method to see where it was leaking.a small mirror will help too.he said the primary shot will dribble if its the neeedle valve thus the whole carb is wet inside, mine is only wet on the bottom, he figures metering block or baseplate.
Old Jul 10, 2005 | 12:41 PM
big69's Avatar
big69
Is there a fuel filter/screen in these Elelbrock Performer carbs?
Old Jul 10, 2005 | 08:08 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
IF the float has a leak, it will sit low and allow fuel to flow into the engine, but only when the pump is running. After the pump stops only a leak will flood the engine.
To float leak causing flooding?
