compression help
Old Jul 12, 2005 | 10:39 AM
Fevre's Avatar
Fevre
I think there is some misinformation on the vac adv can, check Lars' tech papers for the low down on getting the proper set up for your eng combo.
https://www.corvetteforum.com/techti...=115&TopicID=3
https://www.corvetteforum.com/techti...=109&TopicID=3
Old Jul 12, 2005 | 11:47 AM
Hvymtlc5's Avatar
Hvymtlc5
I don't understand why a 11.1 car engine can't run on 92 or 93 and my dirt bike @ 11.5 and my Hayabusa street bike @ 11.0 can with no "ping" ??
Old Jul 16, 2005 | 06:04 PM
pauvil's Avatar
pauvil
this is an easy answer, anyone???
Old Jul 16, 2005 | 07:48 PM
Techno's Avatar
Techno
A very large engine pushing a very heavy load through limited gear (torque multiplication) compared to light load, small engine, many many gears.
BUT the biggest is your comparing an engine that was designed for high octane gasoline.
If a modern engine they are close to this if not at 11:1.
A similar question comes up why a bike 2-cycle can spin so much faster than a merc 2.5 and produce more HP for weight. Smaller engine with gears VS large engine with no gears at all. These engines also are limited by octane.
With high comp heads my 200lb engine dynoed at 340 hp.
Pump gas heads guessed at 280-290. ( on a 1250 lb boat beats my Vette for power to weight )
Old Jul 16, 2005 | 10:35 PM
Simmo's Avatar
Simmo
Pull the manifold and block the heat riser, this will make a difference.
Fit a carb insulator, insulate fuel lines.
Get your motor to run cooler, ie race waterpump, overdrive pulleys, high flow thermostat, better radiator, better fans.
Get a vacume advance canister that is adjustable in rate and amount.
Check fuel mixture.
Cooler plugs.
Lastly change cam timing.
Old Jul 16, 2005 | 11:31 PM
big_G's Avatar
big_G
IMHO, current generation vettes with 10.5 and up compression can use 93 octane because of careful fuel and timing management. Current combustion chamber designs and flat top pistons work to prevent detonation. It will be tough to do with pop-up domes and old head technology without giving up too much performance.
Old Jul 17, 2005 | 06:42 AM
Matt Gruber's Avatar
Matt Gruber
Originally Posted by Matt Gruber
i wrote this hoping it would help
http://community.webtv.net/MATTGRU/pv
so far no takers, just my 2 VETTES
most can't tune their way out of a wet paper bag
