hinge bushing replacement ?
Old Jul 11, 2005 | 10:49 PM
bams12's Avatar
bams12
Default hinge bushing replacement ?
Had my car at the body shop for a door that sags a little and I was told that the hinge bushings on the top hinge needed replacement. Has anybody got any advise on the replacement of these bushings ? Is this a do it yourself job ? Thanx Brent
Old Jul 12, 2005 | 06:00 AM
theandies's Avatar
theandies
Old Jul 12, 2005 | 06:27 AM
Gary79's Avatar
Gary79
this is a DIY job, but you'll want to find an extra body to help hold the door.
Old Jul 12, 2005 | 06:43 AM
any4xx's Avatar
any4xx
I've done it and it's a piece of cake. I did it without any help, but in retrospect, that was a pretty stupid choice. Seriously, get a helper when the time comes.
Old Jul 12, 2005 | 08:53 AM
bams12's Avatar
bams12
Does the door and the hinges need to be removed or is it simpler than that ? Brent
Old Jul 12, 2005 | 08:57 AM
lvrpool32's Avatar
lvrpool32
When i did mine, I removed the door. Make sure you mark where the bolts are first (just "mist" some rattle can primer onto them..makes it easy to return the bolts to their old position)
One trick is to grind down one side of the top hinge pin...that way it comes out past the lip of the front fender...cut a similar notch in the new pin going back in.
Nick
To hinge bushing replacement ?
