Windshield top bar replacement?
Second, let me offer advice, as I have replaced this.
Actually, I replaced everything from the back of the Ttop bar
to about 1/3 down the WS frame sides. Mine required lots of
measurements to get it back together correctly.
If your top corners are in good shape, then I highly suggest
leaving them in place. Cut the top bar somewhere between
the corner pieces and the rusted area. Preferrably, do this
AFTER getting the replacement piece. You could use a new or
used bar. Actually, I might have a spare ... unsure of
condition ... I'll look. The Ttop bar will need the spot welds
drilled out for detaching from the top bar. Then, it's just a matter
of cutting the replacement to the exactly length. I usually cut
a bit long and use a grinder to slowly shorten until it fits tight.
Then, just bevel the ends of the pieces, triple check alignment
and weld away.
Good luck
On a related note, I vaguely remember that there was a trick to removing the chrome windshield trim on the outside, both up the A pillars and across the top. I know that it's held in with clips, but I'm not sure exactly how to release the trim.
screwed on. You have to remove the glued-on weather strips to
get at the screws (3 each I think). Those sides are easy. The Ttop
stainless unscrews up front .... might have to drill a couple rivets in the back.
The top WS stainless clips probably have a special tool to come off easily.
I recall using a screwdriver and bending the piece slightly in places.
Honestly, that was over 3 years ago that I removed it.
Hopefully, someone else will chime in with a good technique.
not to use this one, due to some cheesy patches that someone
had put on the corners. The bar itself is rust-pitted on the
surface that the glass is stuck on to. There is one small hole
rusted through. I'll try to get a picture of it later today, but my
guess is that you wouldn't want to use this piece unless
you have no budget for parts. The rest of the bar is solid, so it
might be OK to exopy the mounting surface smooth. Pics to follow.
Measure from the back of the T-bar to the window seal lip (sticking up that the molding attaches to) and from the center of the T-bar to each corner of the frame and at least one place in between. Mark where you took measurements from and measure from the corners to where you take the measurements between the corners and the center so you can locate them on the replacement part.
Measure from corner to corner also. It is important to write down these measurements and draw a diagram of how you took them so you can duplicate this on the new part. You need at least three points of reference from a central point to each side to be dead accurate. Hop it helps.
(dont forget to measure and locate the center of the old and new parts)
vic
