When I go W.O.T. it pulls great but it wont change to the next gear or increase speed untill I let go of the gas and then it goes int the next gear what is wrong with the trans its really anoing at the dragstrip (my ATV cable is leaking a little bit could that cause the problem)
The kickdown cable attaches to the carb linkage. At the bracket, there is a button that pops out. Pop out the button and the cable will retract into the cable housing. Pop the button back in and then rotate the carb to WOT, that will set the kickdown. The modulator valve is at the passenger side rear of the tranny. There will be a vacuum line running to it. It is held in by a bracket and one screw. Take it out and test it with a hand pump, if it's bad, replace it.
the kickdoen cable was off by about an 1" and I anjusted it (I think this should help with the problem), and the modulator valve is about 2 months old is one of those adjustable modulator valvesI dont think there is nothing wrong with it, I didn't drive yet until tomorrow
