Heater core Help .
Old Jul 16, 2005 | 05:46 PM
ridged84's Avatar
ridged84
Default Heater core Help .
I need to change the heater core and the a/c compressor on my 72 , i can wrench so im not worried about that.Just want to know if this is gonna be a big PITA job?
Old Jul 16, 2005 | 06:04 PM
WayneLBurnham's Avatar
WayneLBurnham
Default It wasn't a lot of fun on the '75...
I assume they are similar.
I did all of mine as all one part of an entire dash, HVAC, etc. rebuild and....wow....what a long nightmare, although I loved the results. (The HVAC part wasn't all that successful, to be honest! )
The heater is kinda at the bottom of the pile of all the ducting and dash guts. Once down there, it's not all that hard. I found every duct was gapped apart. Every controlling vacuum line was off or decayed. The little control doors and pods and such - didn't.
While I was concentrating most of my time on the digital dash conversion and modern radio conversion and wiring and such, I know a number of the 20-odd tubes of epoxy and couple of rolls of black duct tape went in the heater area too.
The little control cables also seemed to be a nuisance routing, IIRC. I think the main one that goes to the control panel behind the big array of vac hoses kept falling off until I modified it somehow.
Old Jul 16, 2005 | 06:07 PM
WhichVette?'s Avatar
WhichVette?
The heater core looks to be a huge pain. Unless you really need a heater, I'd just block the lines and call it a day. The compressor is easy to change, just don't let the weight catch you off guard. That **** is HEAVY!!!
Old Jul 16, 2005 | 07:08 PM
ridged84's Avatar
ridged84
I dont need the heater but the car is 4 sale so i want to do the wright thing.
Old Jul 16, 2005 | 07:30 PM
Techno's Avatar
Techno
Check with a garage on this but pretty sure you can easily switch to the newer type freon. Its a good selling point.
Old Jul 16, 2005 | 10:18 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I had my whole dash apart last summer and put new foam seals around all the duct work. Now my system blows LOTS of air. But even though I pulled the heater core box off the dash, and yea it's a lot of work to get down to it, I never could OPEN the damn box to replace the core.
By that time, my engine had been in for over a year. And when I put the engine in, I had plugged the water holes in the pump and the manifold, so the heater core was already bypassed.
I armwresled the box for an hour, had another beer, and just put it back in with the old heater core inside it. I was getting really frustrated and was bound and determined to start the reassembly.
Next day I returnd the new heater core I'd bought and I still have the old one in place. Lucky me I don't need it.
Old Jul 16, 2005 | 10:42 PM
71SoCal's Avatar
71SoCal
I pulled the heater core on my '71 a few months ago. It does take a little time.
The right-side dash has to come off which means the top dash pad should come off. The center console needs to come out since the a/c ducting needs to be removed. Behind the ducting, and to the right of it are the three screws from the inside, and one nut on the outside firewall that hold the plenum in place.
The two hoses obviously need to be removed from the bottom of the car at the heater core. On the inside, various cables and wires need to be moved aside, then the plenum will pull toward you (assuming you are sitting in the passenger seat). The disconnected heater core will come out with the plenum. Assembly is reverse...
Old Jul 17, 2005 | 12:43 PM
carnut114's Avatar
carnut114
I replaced the heater core in my 72. It took 4 hours. I did most all the work taking the passenger side dash apart. The only thing i had to do under the car was connecting the heater hoses. There was a big rivet holding the heater core box on that i had to drill off with a 12" bit. Other than that is wasn't bad.
Eric
Old Jul 19, 2005 | 12:38 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Did the core on my 72 a month ago. Don't get in a hurry. Remove the following....after you drain the cooling system and disconnect the hoses from the core.
Center instruments...mark the wires for the back of gauges.
Radio....
right side plastic kick panel
front of passenger side dash (map pockets)
Then start taking the duct work out...eventually you will get to the actual heater box. There are 3 nuts inside - and ONE nut outside under the hood that hold the box in. Remove the box and break it open on a bench. Mount the new core and slip back through the firewall from inside. Clean all your parts up and put it back together.
As you go ... take some pics with your digital ... you might need them as you re-assemble. Good Luck .
Old Jul 19, 2005 | 10:06 AM
Paul L's Avatar
Paul L
This may help.
http://www.corvetteforum.net/c3/juli...tCore_orig.htm
Old Jul 19, 2005 | 11:18 AM
kdf1986's Avatar
kdf1986
Hello,
Here is another guide that was posted on the Forum.
http://www.corvettefaq.com/c3/C3CoreReplacement.pdf
kdf
To Heater core Help .
