Headlight raises when engine is shut off
Old Jul 21, 2005 | 08:41 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
You can rebuild the headlight actuators as long as the main diaphragm is not torn. This is an easy rebuild. The control valve are actually rebuildable also. There is a webpage that I used to rebuild mine and they both work great now. Those are not really that big of a deal to rebuild either. The main problem is getting the band off that holds the metal lid, on and off the valve body. Unfortunately I did not bookmark the page that had the pictures of how to do an actuator rebuild in it. And they can be rebuilt for about $.50 as long as the diaphragm in the actuator is not torn.
Old Jul 21, 2005 | 09:39 AM
JLMvette73's Avatar
JLMvette73
This the webpage you're talking about, Eddie?
http://209.183.231.72/corvette-101/relays.htm
