Electric fans for cooling engine
1) Sender belongs in the radiator, because mainly of fan runon after engine shutoff(stop heat soak of aluminum engines and heads, and not have to complicate temp sender). Thermostat will open wide at engine shutoff and convection will circulate coolant.
2) The fan or fans need to be at least 2-3" away from radiator surface to allow air to escape out of fan holes. Needed to eliminate air pileup between radiator and fan/thin shroud mounted directly on radiator. This problem occurs when driving, and fans would be off. At idle this air pileup would be sucked away by fans. Another option would be "flaps" in the area around fan/fans. This is an especially acute problem because radiator is at an angle to air flow.
3)fans need to be angled to blow over engine, and scavenge engine compartment heat. This also works well with 2), and helps cool passenger compartment. I think if two fans are placed at the top of an angled shroud, it would clear all of the suspension junk nicely.
4) A higher output alternator is required for the 30-40 amps used when fans are running. I would say 105 amp minimum.
5) A two step speed control is desirable, mainly because of fan running after engine is off, and energy required. Also staging would reduce the electric spike when fan turns on, and when it turns off.
6) AC control would run fan at low, or turn on one fan of dual system.
7) Turnon temp of sender would be in the 205-215 degree region with a 195 degree thermostat. This has the most subjective or maybe scientific setpoint.
SHIELDS ARE UP!!
SHIELDS ARE UP!!
This person hasn't got a clue on how to keep an internal combustion vehicle's engine cool.
This is probably the BEST list of what NOT to do to your car's cooling system that I have ever seen....
COMPLETELY wrong.
EDIT: well, except the bit about the alternator...
COMPLETELY wrong.
This is how I keep my bigblock in the 180 range.
I have a big tube 1 1/2 tube 2 row alluminum rad.
I run 2 16 inch tornado fans, one low and behind and one high and in front.
I sped the water pump up 30% by putting a small pulley on the water pump.
Finally after alot of testing a motor runs cooler without a thermostat and NO restrictor.
The small spoiler under the front end also makes a big difference.
My motor also runs cooler with the light off and down.
With this setup I never see 200 and most of the time on the highway drive without any fan turned on. The motor stabalizes around 185 degrees with no fan on the open road and a few miles from home I turn both fans on and bring the temperature into the 170 range before shutting down to prevent heat spiking when turning the motor off.
I don't know why a higher output waterpump would help unless there are corners in the block where coolant has a chance to almost stop, and create a hot spot. Circulating the coolant faster(assuming the radiator is doing it's job) should have little effect. You will get slightly warmer coolant into the radiator but it shouldn't have that big of an impact.
Jim
You do need a strong alternator to run multiple fans, but my stock alternator has not had a problem keeping up. I do have my fan thermostat located in the radiator but a better location would be in the block or intake. Everything else seems to bee from outer space and we have never seen any of it in print.
Don't mean to be upset, just would like to know your source of information.
Bernie
You bring up a lot of interesting things to think about there jbs75.
All of the vehicles I have seen in the last 15 yrs. have had fan control sending units in the radiator from the factory. Now mind you this is for radiator fan control ONLY. Fuel injection must be in the block for at least one of the senders, and of course the dash temp guage has to be there too.
Now that I think about it; probably the switch to after engine shutoff fan operation probably occurred with the switch to 195 degree thermostat.
So many have assumed this is a real event with no data to support it.I challenge this even OCCURS!
Again, many have noted, clearly, e-fans freewheel or speed up when hit with increased pressure. Having thin blades and lightweight rotating assys (unlike mechanical fans) they don't take much to spin, have minimal resistance to air flow in the first place and can spin at any speed. Off, they won't eat that much air flow to freewheel; on, they will have only increase the velocity of air going through, even if it's already moving.
Now, if you just mean air piling up in a full sealed shroud, we agree. Lightweight vents, flaps or no shroud at all (and not relying on shroud "vacuum" for fan action) is needed for this.
(you're going to put some on yours, aren't you...AREN'T YOU?!??!
"Sir, she's bypassed like a #(%*in' Christmas tree! She canna take no more direct hits lad!"
Clarifying the air dam situation; I assumed a combined fan/shroud. The ones I have seen are very thin.
If you didn't have a thermostat, you would need a temp sender in the block to take the place of the thermostat plus some additional junk(like an electric water pump/controller). But you would still have a temp sender in the radiator to control some radiator fans.
A single fan with no shroud should be a problem with overheating. I had tried that years ago but the air never left the engine compartment. Adding a shroud and sealing all the extra holes in the sheet metal around the radiator fixed that.
thats why i stick with the stock mechanical fan and shroud. No wiring mess and wimpy electric fans to try and cool the engine.
BTW, mine cools much, much better with my e-fan setup than it did with the mech fans. These are not the e-fans of the early '80's - they really move some air.
Yeah, I would agree a single, medium flow, medium flow fan with no shroud would be very ineffective. It's one key reason I went with three instead of two - more area coverage and I really was concerned about shrouds blocking flow. Therefore I wanted to completely do away with the shroud to allow air flow through the remaining 32% not covered by fans. I honestly had never considered the clever one-way shroud flaps on the SPAL/DeWitt setup....hadn't seen them in person. Ideally I would like some pusher fans, but there is only 1.75" room max between the radiator and the condensor and only room for 2 5" - maybe 7" tops fans in front of that.
As to complexity....mine is anything but complex, and, that which ALL the dinos like DJ (who hasn't bit yet!
) have missed in the e-fan vs. mech fan controversy is the strength of not just a mechanical fan setup, but a flexfan with no clutch - simplicity and reliability of operation.Mine is three fans, two switches, two relays. I have no thermostatic control. I don't even have a thermostat but a restrictor plate.
I consider the trade of an inherently less reliable electric system somewhat traded off by both the increase in cooling performance and the removal of so much vibration and stress from the water pump bearings.
