Hurst shifter - Installation option / question
Old Jul 18, 2005 | 06:39 PM
Frank O'Hara's Avatar
Frank O'Hara
Default Hurst shifter - Installation option / question
I have my M21 transmission out to replace the flywheel - while its out I'm going to install a hurst shifter in place of the GM OEM shifter.
The question is - should I install & adjust the shifter on the trans (minus the handle) before if reinstall it ? or should I install it after the transmission is back in the car ?? I have a 4spd car with the non-removeable crossmember .... Thanks
Old Jul 18, 2005 | 06:53 PM
69ttop502's Avatar
69ttop502
Frank, it is easier to install and adjust the shifter on the bench as that is what I did. However I am not sure you can get it all in with the fixed crossmember. I had installed mine with the engine. Hopefully someone will chime in on whether you can get the trans w/ shifter in.
Old Jul 18, 2005 | 09:47 PM
glen242's Avatar
glen242
My '76 with a BW ST-10 went right in with the LINKAGE attached. Shifter rod (lever) was not attached.
Old Jul 18, 2005 | 09:55 PM
big_G's Avatar
big_G
Bench adjust it (including the stops). Tear down..install trans., then shifter..Just my way...lol
Old Jul 18, 2005 | 10:17 PM
Frank O'Hara
Glen242 - did you have an unmoveable crossmember ??
I can try with the shifter attached (minus the shift lever) and worse case I'll end up doing whet Big_G suggested
Thanks everyone !
To Hurst shifter - Installation option / question
