Hi, I have an 82, which has an l83. I needed to replace the camshaft because it had worn. I ordered a Comp Cam (12-388) and installed it as recommended by Comp Cams(bought the video). I also installed a new (OE) Timing Set. I referred to my Chilton guide and the timing marks for 80-82 are supposed to be at 12 o'clock and 12 o'clock. Something doesn't feel right about this....
When I installed the Distributor it installs at 90 degrees further left that I would expect (compared to when I removed it). I called Comp Cams to confirm my process was accurate and they said I had done everything correctly. I have not put the timing cover on yet because I still have this nagging feeling that something is wrong.
Any direction you could offer would be greatly appreciated.
Thanks.
Bob
Did you drop the oil pan to get the timing cover off? If not then it is possiable to start & run the engine FOR LESS THAN A MINUTE to double check things before buttoning it up. Personally, I would pull #1 spark plug, bring it to top dead center compression and verify that the distributor rotor is facing #1 on the cap.
When installing the camshaft, the dots on the crank gear and cam gear should be directly opposite from eack other. Cam dot at 6 o-clock, crank dot at 12 o-clock, like Chevy has been doing forever. That beign said, that is the firing position for #6. Now, after the cam bolts are tight, you may rotate the crank 360 degrees to the #1 firing position. Cam dot is now at 12 o-clock, and the crank dot is at 12 o-clock. Now stab the distributor....
I haven't pulled one so I dont have personal experience.. but I have read a number of times where there's a pin inside the shaft where the distributor is installed that can block it from seating properly. I think it was either a big old screwdriver to push that in or a bump the engine until it synchs with the distributor.
The "pin" you refer to is the top of the shaft that drives the oil pump. The top of the shaft has a slot that you can use a screw driver to it.
Install the cam with both dots at 12:00 (straight up). This is top dead center on the compression stroke for #1. With the cam installed in this position, you should drop the distributor in so that the rotor points to the #1 tower in the cap with the distributor body in the desired clocking position. The distributor can be installed in any position you choose, but the correct orientation for the HEI is with the electrical connection pointing squarely out to the driver's side at 90 degrees. In this position, you need to point the rotor to the #1 tower in the cap, which is the forward driver's side tower. With the dstributor installed like this and both timing dots pointing straight up (12:00), the engine will fire and run.
Note that the you can install the cam with both dots either straight up or pointing together since the cam rotates at 1/2 crankshaft speed. Either way will give you a correct cam installation. It's just that for correct distributor installation you need to have both dots straight up to be in the firing position for #1.
Thank you everyone. I will finish this project up this weekend and post another reply. On a side note, I find this forum invaluable. I am a novice and this is the first project I am attempting. It is great to know you are there. I hope that I will be able to assist someone else once I cut my teeth.
Oh, after you have TDC on your gears etc, don't turn it until you put your balancer on. In case your balancer has slipped you can mark it with something (a line of orange paint is pretty easy to see on mine). On mine the balancer timing mark was nearly 90* off. I also marked the INSIDE of the lower pulley (which will always stay lined up with the crank/keyway/etc) in case the balancer ring slips again.
Murphy-Let us know how the cam swap results are. Im interested in this as I may be putting this on my to do list for maybe next summer on my 82.
The Cam is installed and the car is running. A little rough but some tuning will fix that. I was having trouble starting the car and went through eveything before I notice I had no compression. I followed the directions about setting the valve train to 0 lash + 1/2 turn. I over tightened the valves leaving them open(I followed the instructions on the video). I found an article that stated move the push rod up and down instead of spinning them. When I did that my compression returned and the car started on the second crank.
I can tell the car runs much smoother and has a lot more power. The whole thing took me about 16 hours and I am a novice.
I still have a check engine light on so I am going to buy a cheap code reader and troubleshoot the codes that it returns.
Let us know how this turns out. I've had input from several people that changing cams on these computer controlled cars can be a bit of a bear. The computer gets unhappy very easily.
If, however, you found an aftermarket cam that works well in these, that would be very useful information.
You can read the codes with the use of a paper clip. Just connect the test terminals and the check engine light will flash all the stored trouble codes in a sequence. Look in the manual for specific codes etc.
How much different is this cam than the stock one. Too much different and you may have to do some tunning. You may want to build a ALDL cable and talk to your computer to get a better idea of what the issue might be.
Sounds like you're still mostly stock. If you have issues with it you can always ask over at the crossfire site. They might know exactly what you're up against.
