Technical Gasket Question from Downunder
Old Jul 20, 2005 | 07:01 AM
Aussie One's Avatar
Aussie One
Default Technical Gasket Question from Downunder
I was about to fit new head gaskets when I noticed that the three large water holes in the heads & block are about 3/4" dia whereas the matching holes in the Victor Reinz gaskets are only 1/8 " dia. Can anyone give me a reason for this? Would it be wise to open up the gasket holes to the same size as on heads & block - coolant would flow faster through the heads hence lower engine temp.
Old Jul 20, 2005 | 07:24 AM
gerry72's Avatar
gerry72
No. It would be a huge mistake. The size of the holes in the gasket regulate the water flow paths. Some water will go from the cylinder jackets into the head. Most of the water will go from the pump, through the cylinder case to the rear of the block, up the large passage at the rear, into the rear of the head and pass through the head to the front where it will exit the head into the intake manifold.
This keeps the coolant temperature variations more or less even throughout the block and head. If you enlarged the holes, the front of the head would run much cooler than the rear since the water will take the path of least resistance.
Old Jul 20, 2005 | 07:58 AM
WayneLBurnham's Avatar
WayneLBurnham
Default I always wondered about doing that....
that seems a very good point. I came very close to doing that with some copper head gaskets when, I guess fortunately, the great gods of laziness intervened and prevented it....
Old Jul 20, 2005 | 09:05 AM
zwede's Avatar
zwede
Gerry is correct. Water flow is regulated by the gasket. Enlarging the holes will mess up the flow rates front/rear and lead to problems. Everything I've read indicates the Chevy V8 cooling system is excellent and should be left as designed.
Old Jul 20, 2005 | 01:03 PM
Solid LT1's Avatar
Solid LT1
The large holes are to get rid of the casting sands after the block is cast at the foundry. Most HP motor builders tap the deck and put a 3/4NPT plug into these holes, drill 1/4" holes into the pipe plug for water circulation. The pipe plug helps stabilize the top end of the motor at the m ost critical area around the top of the cylinder bores but, it must be done before final machine work is performed on the cylinder bores. I do this on any engine I anticipate making over 400HP with when I'm using a production type cylinder block.
Old Jul 20, 2005 | 07:18 PM
Aussie One's Avatar
Aussie One
Thanks to all who replied & for all the good oil on the gaskets - I will leave the gasket coolant holes as is. What would we do without the excellent advice on this forum!!!!!!!!!
To Technical Gasket Question from Downunder
