centriugal advance pins?
Old Jul 21, 2005 | 07:44 PM
73'454folendore's Avatar
73'454folendore
Default centriugal advance pins?
I was replacing the weights and springs in the distributor. As soon as I took off the rotor cover one of the spring pins with the spring took off. I can not find them even with a magnite throughout the whole engine. Got a new set of balancers and springs today but I can't find the anywhere to find the lost pin that was holding down the weight. I also cannot find a centrifugal advace with the pins included. Trying not to replace the whole distributor. any advise an to replacing just the missing pin? Thanks
Old Jul 21, 2005 | 07:51 PM
Gordonm's Avatar
Gordonm
It should be in the distributer somewhere. The cap should have contained any small parts that let go. I don't know about the pin that is missing. I don't know where you would get one. It is probably a press fit and the hole just got oblong and the pin came out.
Old Jul 21, 2005 | 10:24 PM
MIKER's Avatar
MIKER
Unless you can find the pin or a donor distributor to rob the parts from, I suspect you will end up having to replace the distributor.
Think of it as an opportunity for improvement
Let us know what you come up with.
Old Jul 21, 2005 | 10:36 PM
big_G's Avatar
big_G
And lose the points! (sorry for beign blunt)
I hope you find the missing parts....I wouldn't sleep thinking they went into the engine!
Old Jul 21, 2005 | 10:45 PM
BigBlockk's Avatar
BigBlockk
Make a new pin out of a piece of drill rod.
BigBlockk
Later.....
Old Jul 21, 2005 | 10:54 PM
carl a's Avatar
carl a
I Dumped My Distributer And Got A Msd,one Of The Best Moves To Make!
Old Jul 22, 2005 | 03:31 PM
69monzaredbigblock's Avatar
69monzaredbigblock
Contact Lars. I'm sure he has the parts. He overhauled my distributor and I believe he had an inventory of spare parts.
To centriugal advance pins?
