Setting the points gap
Old Jul 22, 2005 | 07:18 PM
BUGGSY1970's Avatar
BUGGSY1970
Default Setting the points gap
I am replacing the points on my 70 for the first time and I am having trouble setting the gap.
With the condenser I can't get the feeler gage intothe points to check the gap. I can't reach it from the top because the weights are in the way.
This is the first time I am doing this in 25 years. What am I misssing?
Old Jul 22, 2005 | 07:23 PM
jake1's Avatar
jake1
Go buy a point gap meter from the parts store, and just use the allen wrench adjustment on dist. while you look at the meter. Much easier.
StickShiftCorvette's Avatar
StickShiftCorvette
You should set the points using a dwell meter-NOT a feeler gage.
The dwell meter hook up to the coil on the distributor side and ground, and depending upon the model to power. Most Chevys are set at 28 to 32 degrees dwell although some high performance models are different-you need to check the specs in the manual (service or possibly owners).
Old Jul 22, 2005 | 07:47 PM
Z-man's Avatar
Z-man
You should be able to get close without buying a meter. I can't figure out where your problem is with the condenser, though.
Here's how I always do it:
- Remove dist cap and rotor
- loosen the screws that hold the dist plate slightly
- rotate engine by bumping starter (or remote starter switch) until the points are resting on the peak of the cam
- stick a screwdriver into the adjusting slot and adjust the point until they are at the correct gap (are you using a matchbook cover like you are supposed to ? )
- tighten down screws and replace cap and rotor
If your distributor is one of those fancy new ones, you can reach through the window with an allen wrench to adjust the dwell, but you'll need the meter then...
good luck -
Old Jul 22, 2005 | 09:25 PM
Techno's Avatar
Techno
This is outside the question but it is well worth it to replace the point system with any of the many pointless type.
They never wear and you never have to adjust it. Instead of investing in a dwell meter put the money towards it.
If this is an original thing you can switch it back at any time.
Old Jul 23, 2005 | 12:09 AM
72-LT1's Avatar
72-LT1
Why can't you get the point gap you want using the feeler guage and adjusting the screw that you turn when using the dwell meter?
Old Jul 23, 2005 | 12:54 AM
desi's Avatar
desi
I just did the conversion on my 74 with the crane XRi unit. For $65, with built in rev limiter, you can't go wrong. Much smoother idle too
Old Jul 23, 2005 | 04:37 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I hear the Crane unit is a good one.
I used the Pertronix Ignitor II ....
Works great....but it idles TOO SMOOTH !
Old Jul 24, 2005 | 09:54 PM
BUGGSY1970's Avatar
BUGGSY1970
I want to keep the car original so I don't want to change to electronic distributor. Also I have had a Petronics system in another car before and it was crap. Left me high and dry 2x in a previous vette before I ditched it and went back to a points distributor.
I ended up setting the gap with a dwell meter. I thought it best to set it roughly with a feeler guage and then fine tune with the dwell meter. Unfortunately the positioning of the condenser on the points kit I got made it impossible to get a feeler guage on the points.
I installed the kit started it up and used the allen wrench to set the gap with a dwell meter. Car runs like a champ. Thanks for all your helpful comments.
Old Jul 25, 2005 | 08:32 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Tony: Good idea on keeping the points
Just curious...are the points you bought one of those "unified" sets where the points and condensor are attached to each other? Sometimes those can be a pain to get at. Just a thought.
Also, if you do any high RPM driving, you can get heavier duty points with a stiffer spring that will prevent "point bounce" at higher RPMs.
NAPA stores have them or Jegs sells them under Accel's name.
There are two different spring tensions you can get. One is SUPER stiff and should only be used at the strip. One is moderately stiffer and can be used for street/strip. Got this info from Lars
Dep
Old Feb 12, 2023 | 04:04 AM
PBCloud's Avatar
PBCloud
Default Rougth Setting of Points Gap
Dep
I also found that in rough setting the gap so I could start the engine to check it with a dwell meter a feeler gauge blade will not fit. I just ground down an appropriate size blade (used 0.020") using my power drill and a small grinding stone (stay safe - use goggles safety equipment etc) to make it narrow enough to not foul the contact breaker mechanism and then ground a curve on the bottom of the blade to avoid the screw holding the contact breaker plate to the distributor. Note I had the distributor on the work bench which made it easy to grind the blade to the correct shape, but now I have the useful tool in my tool box for future use.
Old Feb 12, 2023 | 08:29 AM
Mooser's Avatar
Mooser
Although the information might be helpful, adding to an 18 year old thread isn't usually isn't the best way to get it out there
M
Old Feb 12, 2023 | 08:43 AM
kanvasman's Avatar
kanvasman
Ha! I get sucked into these things all the time. The first clue was. POINTS.
Good thing he wasn’t trying to a DUAL point distributor.
Old Feb 12, 2023 | 08:51 AM
Mooser's Avatar
Mooser
Originally Posted by kanvasman
Ha! I get sucked into these things all the time....
Yeah, I had to turn off the "Related Threads" option so I didn't end up past the end of whatever I was looking at
M
Old Feb 12, 2023 | 10:00 AM
PBCloud's Avatar
PBCloud
Oops! did not notice date I was just serching on Goggle for correct points gap and this came up.....should be more on the ball.
Its good to kmow you guys are on the ball for me......!
Setting twin points must be fun, I only have the single set.
Paul
Old Feb 12, 2023 | 01:41 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Chevy point sets are adjusted with the allen wrench, and a dwell meter, AFTER the points are installed, and the engine is running, I've found the case to be that the points are "close enough" right out of the box, so you can at least start the engine, and only need a little "fine tuning" after the installation.
And YES, i realize this thread originated 18 years ago.........and the last time I set the dwell on a set of points, was about 18 years before that!!
Old Feb 12, 2023 | 02:07 PM
PBCloud's Avatar
PBCloud
Looks like I have reignited this thread; dwell meter is definatly the right way to go, but so is following Lars paper for first setting up the distributor and timing correctly (which was invaluable) before you even get to the points.
Having only joined the forum a few years ago I did not realised it had been running for this long; I wonder just how many Corvette owners it has helped in that time.......
Paul
To Setting the points gap
Old Feb 14, 2023 | 09:33 AM
kansas123's Avatar
kansas123
Didn't we use to use a matchbook cover to set the gap, back in the olden days?
Old Feb 14, 2023 | 09:36 AM
Mooser's Avatar
Mooser
Where can you get a matchbook these days? Those vape things don't need fire I don't think
And if you did get one it's probably made so much thinner/cheaper these days the points would probably be touching all the time
M
Old Feb 14, 2023 | 10:19 AM
kanvasman's Avatar
kanvasman
And made in China so the quality won't be the same.
