Need help with problem starting
Old Jul 22, 2005 | 09:11 PM
LS1Bird's Avatar
LS1Bird
Default Need help with problem starting
Hello all, my friends 72 Convertible after much restoration won't start.(turn over) It's been almost 2 years since it's ran. It's a 350 and it's been almost 2 years since it's been even turned over. The starter and selonoid tests good.
Here's where I'm at, we're getting 12 volts to the starter on the main battery wire. Getting 12 volts to the small terminal "R" on the starter. The "S" small terminal is zero volts with key in start pos. Is the "S" terminal on the starter supposed to be the wire from the ignition switch? If so looks like a bad switch if that's the case but I'm not sure.
Thanks for any help or insight!
Oh yea, one more question, we're wondering about the neutral safety switch as well. what's the best way to bypass it? Thanks again..
Old Jul 22, 2005 | 09:35 PM
big_G's Avatar
big_G
Test the neutral saftey switch, don't remove it. It sounds like the wire from the ignition switch may indeed be the culprit. G/L
Old Jul 23, 2005 | 02:32 PM
LS1Bird's Avatar
LS1Bird
Thanks for the help. It actually ended up being the "new" ignition switch. Installed the old one and voila! Thanks for the g/L response Big G.
Old Jul 23, 2005 | 02:58 PM
big_G's Avatar
big_G
Your Welcome
To Need help with problem starting
