78 speedo problem
Old Jul 26, 2005 | 11:15 AM
ChevyL82's Avatar
ChevyL82
Default 78 speedo problem
how hard to bypass cruise transducer? Replace with non cruise cable? Need info on level of diffucilty
Old Jul 26, 2005 | 11:18 AM
Star79's Avatar
Star79
see this link for a couple of options:
http://forums.corvetteforum.com/show...707&forum_id=3
Old Jul 26, 2005 | 12:01 PM
Ganey's Avatar
Ganey
The longer non cruise cable will work, easy enough. Easier, try a lower cable for 86-88 SS Monte Carlo which may work by connecting directly to the upper cable.
Old Jul 26, 2005 | 02:55 PM
Retro78's Avatar
Retro78
I took it out....and just replaced the two short cables with a long one..no problems.
Old Jul 26, 2005 | 09:18 PM
markdtn's Avatar
markdtn
A non-cruise one is easy to install except getting the end through the firewall grommet.
Old Jul 26, 2005 | 09:36 PM
carl a's Avatar
carl a
not to hijack this thread , but i noticed on the bloomington road tour my speedo was reading like 25 when i was doing way more then jumped up to what i was really doing,,new 2 piece cable,(new trans for that matter everythings new) also when i installed the cable i also bought the cable lube and coated the 2 cables good before i assembled them,,,just started doing this,,, dirty needle on the guage???
Old Jul 26, 2005 | 09:52 PM
Ganey's Avatar
Ganey
Carl
That would normally be the transducer going out w/ 2 cables. With one cable, then the cable. It can also happen after the cable has taken a set & someone moves it, moving back can fix.
Old Jul 26, 2005 | 10:11 PM
carl a's Avatar
carl a
i dont have a transducer,all i did was replace both cables they are a 2 piece design and its worked fine till now,,carl
To 78 speedo problem
