front lower control arm...almost done
Old Jul 28, 2005 | 01:08 PM
SharkAttack's Avatar
SharkAttack
Nice work. I'm anxious to see the sway bar you're describing.
Old Jul 28, 2005 | 01:10 PM
Twin_Turbo's Avatar
Twin_Turbo
dave, one can never have enough vise grips I have even more, those are just the ordinary ones, not the welding clamps and such.
Shark attack, it'll probably take a couple of weeks or more for me to get at the sway bar stuff, still need to finish up the upper shock mounts and cross bar and for that I need to pull the engine again.
Old Jul 28, 2005 | 09:45 PM
norvalwilhelm's Avatar
norvalwilhelm
Marck are you going to run a rear bar. I keep toying with the idea of installing one.
Old Jul 29, 2005 | 03:07 AM
Twin_Turbo's Avatar
Twin_Turbo
Yes I probably am, something needs to control the roll in the back now that there's no spring to connect both sides.
Old Jul 30, 2005 | 07:02 AM
Twin_Turbo's Avatar
Twin_Turbo
Here's what I came up with for the front sway bar...this will work just fine (especially when I install a splined speedway bar w/ seperate arms)
Old Jul 30, 2005 | 09:42 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
thats nice but it looks heavy. What do you estimate you car is going to weigh when done. It might be more than you think.
Old Jul 30, 2005 | 09:49 AM
Twin_Turbo's Avatar
Twin_Turbo
what is heavy??? The car will probably weigh less than stock, a lot of heavy things have been replaced or removed. The front frame extension will also be replaced by a new one made from scratch, the stock thign is quite heavy. Those 2 mounting blocks for the sway bar weigh next to nothing. I don't have the heavy stock calipers, my upper control arms weigh a fraction of the stockers, same for the trailing arms, no inner fenders and misc. stuiff relating to rad shroud and fiberglass there.
Old Jul 30, 2005 | 10:50 AM
turtlevette
You've added a lot of steel reinforcements in the car, so i'm just wondering.
Its my opinion that we need to get these cars under 3000 pounds to have any chance of making them competetive. Power alone will not get you fast lap times.
Old Jul 30, 2005 | 10:58 AM
Twin_Turbo's Avatar
Twin_Turbo
That steel weighs next to nothing, it takes a lot of steel to add a significant weight and it sure is less than all the stuff I'm leaving off the car. I probably won't be able to get it under 3000 pounds.
Old Jul 31, 2005 | 07:02 AM
bowtie racing's Avatar
bowtie racing
Just say NO to cast iron
Old Aug 1, 2005 | 01:13 AM
bowtie racing
Looks really good Twinnie.That coilover position is best possible.
Old Aug 4, 2005 | 02:09 PM
holley425hp's Avatar
holley425hp
Sure it looks great.
I left alot of those heavyweight stuff out of my car and planning to go with those aluminum calipers from VBP.
You're making nice progress.
I think I will be planning to pay you a visit in about two weeks, because I need to get the rocker panels you got for me.
I'll give you a call soon. Good luck with the project.
Ryan
Old Aug 4, 2005 | 02:43 PM
  #33
rcread's Avatar
rcread
Ryan
Do you mean the aluminum calipers from Stainless Steel Brakes or is VB&P making aliminum calipers too now?
Old Aug 4, 2005 | 02:51 PM
  #34
holley425hp
Sorry VBP ,
My bad guys, I meant the aluminum brakes from VAn Steel the force 10 calipers.
Greetz,
ryan
