HEI Conversion Wiring Question
Old Jul 28, 2005 | 09:27 AM
OldSchool's Avatar
OldSchool
Default HEI Conversion Wiring Question
I am converting from points distributor to HEI and know that I can't use the points resistor wire for my HEI. Where is the best place to tap for 12v power for the HEI?? Horn Relay? Any particular lug?
Thanks in advance..I'm getting close to firing this guy up!!!!
Steve
Old Jul 28, 2005 | 09:30 AM
pws69's Avatar
pws69
Steve
Horn relay is HOT all the time, so not suitable for Ignition.
I ran a wire to the fuse block plug labeled IGN for mine - this is switched and works fine.
Old Jul 28, 2005 | 12:56 PM
markdtn's Avatar
markdtn
Just replace it where it comes through the firewall plug. The resistance wire is on the engine side, not the dash side.
Old Jul 28, 2005 | 05:49 PM
68/70Vette's Avatar
68/70Vette
One of the wires that goes to the windshield wiper motor is a "switched hot" wire; i.e. the wire is "hot" when the ignition switch is turned on. Someone posted a message about this. My recollection is that it is a yellow wire. Anyhow, switch on the ignition and probe the windshield wiper motor wires.
To HEI Conversion Wiring Question
