Smokes when starting.....
Old Jul 28, 2005 | 06:00 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Smokes when starting.....
Not everytime...but sometimes...whenever I start the car, after it sits a while, I notice a blue/white smoke come out the tailpipe...then it's gone. Not much of it just a quick "burst". What does that mean? I check the oil....about 1200-1500 miles to a quart (acceptable)...engine runs strong....gets about 15 mpg. Any info on this will be appreciated!
Old Jul 28, 2005 | 06:01 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Sounds like the valve stem seals are worn.
Old Jul 28, 2005 | 06:11 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
I would check intake manifold bolts (especially if you run an aluminum intake with cast heads).
Check your PCV valve as well...that was my problem.
trw
Old Jul 28, 2005 | 07:44 PM
carl a's Avatar
carl a
do you notice smoke coming out when your clipping down the highway and you let off the gas? if so its valve stem seals,vaccume drops when you do this .
Old Jul 28, 2005 | 08:33 PM
vetteguy75's Avatar
vetteguy75
No, only when I start the car....and it happens every so often....
Old Jul 28, 2005 | 09:26 PM
Chopper Larry's Avatar
Chopper Larry
Worn valve guides or valves.
Old Jul 28, 2005 | 09:27 PM
Chopper Larry
Nice car..you should probably just trade me for my 80!
Old Jul 28, 2005 | 09:33 PM
big_G's Avatar
big_G
MIne smokes too.....when I dump the clutch @ 6,000 rpm
Old Jul 28, 2005 | 09:41 PM
Pete76Shark's Avatar
Pete76Shark
Old Jul 28, 2005 | 09:47 PM
Pete76Shark
Vetteguy75 where did you get that cover for the wiper arm bay ?
I like that way it looks, actually I like the way your entire car looks..
Old Jul 28, 2005 | 11:21 PM
vetteguy75's Avatar
vetteguy75
Thanks! I really appreciate that! I got the wiper cover from Ecklers and then painted it to match the car.
Old Jul 29, 2005 | 01:55 AM
easyian's Avatar
easyian
4th Gear
Could just be a rich condition if it is closer to black smoke. But blue smoke is most likely valve guides/seals.
Old Jul 29, 2005 | 07:08 AM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Originally Posted by vetteguy75
Nice Vette!
Old Jul 29, 2005 | 09:34 AM
CMYC4GO's Avatar
CMYC4GO
Your drainbacks could also be clogged, causing oil to pool in the heads, as well as worn valve seals/guides.
Old Jul 29, 2005 | 10:05 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Old Jul 29, 2005 | 01:03 PM
jlaw68's Avatar
jlaw68
my truck was doing the same thing, put in a set of ceramic vavle stem seals and that cured the problem
To Smokes when starting.....
