adding a/c or PS
Old Jul 28, 2005 | 08:48 PM
70 roadster's Avatar
70 roadster
6th Gear
Default adding a/c or PS
Can someone guide me to more info on adding a/c and or powersteering to a 68?
Old Jul 28, 2005 | 11:09 PM
carriljc's Avatar
carriljc
Default I've done PS and am doing a/c
I added power steering to my 68 back in 1991. Nowadays I would consider converting to one of them Steeroid systems instead of just converting to power steering.
I am in the process of adding Hot Rod Air right now...I may get the system charged this weekend...
You can get power steering kids from Mid America and other vendors...many choices.
Old Jul 28, 2005 | 11:30 PM
foundvettelifeisgood's Avatar
I added PS via Steeroids plus a stock PS pump, bracket and March pulley. It's a big improvement and a fairly easy install on a manual brake car.
Old Jul 29, 2005 | 09:22 AM
GTR1999's Avatar
GTR1999
You should do some reserch before deciding. I was going to add PS to my 69 until I rebuilt the steering box and replaced the old G60 tires with 225 70 x15's. It was a night and day difference. I had collected most of the PS parts too.
I have a classic auto air system now that I'll be installing within the next week or two. I chose it over others because it retains the stock controls and has cleaner look.
A rack & pinion system and aftermarket ac run about $1,100 each too.
Gary
Old Jul 29, 2005 | 10:08 AM
markdtn's Avatar
markdtn
I rebuilt my stock p/s setup. If I had it to do again I would convert to the Corvette Steering converted Jeep box. I really like the way they look. You can get a stock conversion from Vette Brakes, a forum sponsor, or at least they used to be.
I added factory a/c to mine too. I used stock 78-82 stuff. You really need a 68-76 inside box (because of the controls) and a 78-82 outer box (to get orfice tube instead of VIR/POA). On a 68-72 you have to clearance the corner of the fan box just a little-no big deal. To add factory a/c correctly you have to take the front clip off and add the recirculate door on top of the rh cowl and block off the fresh air door on the lh cowl. I also plan to upgrade to a C4 fan soon.
Old Jul 30, 2005 | 12:17 AM
carriljc's Avatar
carriljc
Default Charged the A/C system with R-134 today....
Finished installing Hot Rod Air system today and charged it. Got a discharge temp of 38 degrees. Looks like this project may work out.
Old Jul 30, 2005 | 08:13 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Carl, we need a separate thread with all the gory details and some cool pics. I have given some thought to this one also. I almost melted last weekend while out in my vette. It was 95* plus last weekend and I was very glad to get home.
One note to be aware of, if you are converting from stock manual steering to stock PS, be sure to get the PS pitman arm or you will wind up hurting yourself. I found this out luckily while my car was still on jackstands. The car would steer in one direction fine. Steering in the other direction resulted in the wheel whipping to full lock and wanting to go further. A very scary situation.
Old Jul 30, 2005 | 08:14 AM
Eddie 70's Avatar
Eddie 70
I am getting ready to go out in the garage and start tearing out my stock PS system and install Steeroids. This should be fun.
Old Jul 30, 2005 | 03:29 PM
The bulk hardware install of Steeroids is very simple and fun. The fine tuning to make it bind-free is the non-fun part, but worth the effort.
To adding a/c or PS
