Starter engages too early
Old Jul 30, 2005 | 03:02 PM
lilgto's Avatar
lilgto
Default Starter engages too early
Just finished the wiring on a new 383 in a '69 using a promaster mini starter, and an external solonoid. When i turn the ignition switch to the "run" position (right before the "start" position) the starter engages and starts the motor. . . but starter continues to spin as well. The rod in the ignition switch is lined up as is the lock cylinder.
I don't think it's a shimming issue (which i experimented with any way) since the problem is that the starter kicks in too early.
Any ideas would be really appreciated.
thanks,
Mike
Old Jul 30, 2005 | 03:50 PM
big_G's Avatar
big_G
You have either a defective ignition switch, or a short between the "start" and "run" wires coming off the switch......Or you are using the "run" wire on the "start" terminal on the starter solenoid.
