Tach Filter ???
Old Jul 29, 2005 | 03:54 PM
mvftw's Avatar
mvftw
Default Tach Filter ???
If your tach filter is bad or not connected, what is the symptom?
Does the tach read higher values?
Old Jul 29, 2005 | 04:25 PM
C3nMe's Avatar
C3nMe
A range of things have been reported. Some have stated that nothing changes when the filter is bypassed. Others stated that the readings are a bit more erratic. I have mine installed, and except for a small range, the tach works, and it works when I bypassed it for testing.
In most cases, it was supposed to protect the delicate electronics in the dash that run the tach. I can only speak about my experience with my '77 ...even bought a replacement board that didn't work until I re-did all the solder connections.
Brian.
Old Jul 29, 2005 | 05:10 PM
NHvette's Avatar
NHvette
Recently, someone reported double values on their tach ...
turned out to be an adjustment on their replacement tach circuit board.
It is my professional opinion that the tach filter will not
effect the signal - to read consistently offset. The problem is
more likely in the circuit board. A faulty filter might give erratic
readings, or allow the new circuit board to become damaged from high
voltage transients.
Here are a couple links, one long post on filetrs, and an analysis
that I did of the two filter circuits in question.
http://forums.corvetteforum.com/showthread.php?t=913235
http://nhvette.homeunix.com/ftp/in/N...ilter_comp.pdf
To Tach Filter ???
