I have a stock 71 LT1 with stock Holley carb and A.I.R removed. Car used to idle fine and now will not idle when hot. Idles ok 8-900 rpm until it warms up, then slowly dies at a stoplight. Checked timing - 14 degrees initial, idle mixture and idle rpm set. Even took fuel tank cap off to see if it was not venting properly with no luck. Hotter it gets shorter time it will run. Have also sprayed around bottom of intake and carb for leaks and nothing. Retorqued carb and intake mounting bolts/nuts. New fuel filters installed. Also checked vacuum hoses and no leaks unless I missed it. Plug wires and coil are new in the last year. Choke seems to work ok - butterfly almost closed when cold and open when hot. Also new PCV valve did not help. Checked float levels at bottom of sight plug.
Don't know how to check vacume advance but why would that be different with higher temp?
any vac leaks?? when she's warm things tend to expand, crack the throttle and see how fast she comes back down, if it takes a little bit then you have a vac leak.
What happens when the float gets stuck? If it stuck at the top of the bowl then the bowl would not refill unless I blip the throttle (?) How do I check for a stuck float?
If the float is stuck it should be stuck and would run lousy cold or hot.
I don't understand how Hinz-73 fix worked since the pressure has a limit. Any more than about 6 psi and your forcing the needle off its seat, regardless of how much fuel is in the bowl and whether the float is trying to close the valve. Maybe he went from 4-6?
I did the same fix but it was for hot soak with the engine off, for the same reason. Electric pump came with a regulator.
Check for vacuum leaks. What does your engine idle at when hot but not dying?
As the car heats up the idle gets lower. Starts off around 900 when cold, then 800 when warm, then 700 when hot, then drops to 0 over about a 5 second period and shuts off. What is the best way to check for vacume leaks? I have inspected all the hose within easy reach and all looks ok and have sprayed carb cleaner aound the base of the carb and intake. If I plug my vac guage directly into the vacume advance what should it read at idle?
With the choke off, so that the primary throttle plates are completely closed, and the throttle spring removed, grab a hold of the throttle lever on the primaries. Wiggle it up & down.... but NOT side to side. Side to side (passenger to driver) movement is normal. If the shaft moves a lot in its bore, then your carb may need bushings in the throttle shaft bore. Typical symptoms are a rough, non-adjustable idle when hot (choke is off). Air goes between the shaft and its bore causing a lean condition at idle... which the idle ports cannot compensate for. The mechanic typically turns up the idel set screw until the carb is running on the non-adjustable transfer slot/ports instead of the adjustable idle circuit. When the choke is set, the engine gets enough gas. When the choke goes off, the system leans out & stalls.
Another symptom is that the engine idle is erratic... as the shaft intermittently seals & unseals between the shaft & bore.
This may not be your problem as there can be several causes, but it is a common problem with old Holleys. I have the tooling to repair this and have done many of these, and also many Q-Jets with the same problem.
Don't overlook the obvious... Make sure both your idle speed screws are adjusted properly. It almost sounds like once the choke comes off, you die...any chance the primary idle screw is set wrong? Fast (dead cold) idle should be higher than 900, BTW. My HOT idle is 800.
Just a slightly applicable anecdote... One time I replaced the jets in the main meter block and when I reassembled the carb (on the car) I couldn't get it to start when cold. It was fine when warm, though. It just gave me hell trying to get it started when cold. I just couldn't figure out why all of a sudden I had problems. The frustration was kindof blinding me to the real issue. I pulled the plugs and cleaned/gapped them, checked the ignition, fuel pressure, etc. Turns out that when I re-assembled the front bowl, I forgot the accelerator pump arm. Since the carb doesn't have a choke, I wasn't getting any fuel unless I floored it and got the secondary shooter going. Simple crap seems to cause me the most frustration.
Also make sure that your exhaust heat riser valve is working properly. An overheated intake manifold can cause some very funky low-speed carb problems.
I recently wired the exhaust riser open after finding it was essentially rusted shut. This idle problem began occuring before that and has recently gotten worse. I will take a look at the throttle shaft next.
Trouble shooting my poor idle today and found something. After removing the top ignition shielding pieces and checking to make sure all plug wires went to the correct plug I started engine to look for any arcing with big garage door closed for darkness. Didn't see anything but-- when I began reinstalling the side shielding with engine still running the passenger side shielding began arcing around the wingnut hole in the orange shielding support arm. Drivers side does not do it. All plugs wires on that side are firing. I removed one at time to see if removing one would stop the arcing - it did not.
I don't have a spare plug wire but will get one today and substitute it for one at a time to see if that will eliminate the arcing and improve idle etc. I am guessing that the 2 or 4 wire is pinched in the engine mount.
Possibility of you idle mixture being to rich. Mixture screws should be 1 1/2-2 1/4 turns out on a stock LT-1 Holley. You may also have a blown power valve on Holley. Is your idle stop soleniod adjusted correctly? another posibilty.
I have checked the mixture screws and they are ok. I don't have an idle stop solenoid - removed long ago by a PO. Car used to idle ok so I don't think the lack of the solenoid is the problem.
What are other symptoms of a blown power valve? How do I check mine?
Now theres a good thought but it idled ok for over a year and now is getting worse. Can the fuel pump gradually deteriorate like that? A good thing to check tho as there might be an obstruction in the line or something. What should the fuel pressure be at idle?
Also read further up this thread to place a palm over the primary side of the carb at idle and listen for a change in rpm. I did this several times today and idle did not change. Does this eliminate a vacume leak?
So noone thinks the arcing on the passenger side plug wires is the problem?
Thanks again for all the suggestions. I am learning alot as I go here.
Neil
Your hand over the carb. gives no change, then not lean...Yes, a fuel pump can fail over a period of time. And, an obstruction is a remote possibility....Fuel pressure should be 4 to 5 lbs. min. at idle, up to 6 or 7 max.
