Missing idle adjusting needles?
Old Jul 31, 2005 | 05:52 PM
yellow71's Avatar
yellow71
Default Missing idle adjusting needles?
Just discovered something possibly significant with my stock Holley model 4150 on 71 LT1. My forward metering plate has an idle mixture screw in both sides of the plate (2) and my secondary plate (rear) does not have any (holes empty on both sides).
My Haynes Holley manual shows adjusting screws in all four holes. Is this correct? I know mine has never had more than 2.
What is the correct setup? If only 2, which holes do they go in?
Maybe this is why I can't get the idle right.
Neil
Old Jul 31, 2005 | 07:50 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Some 4150's do have 4 corner idle adjustment but not all. It sounds like your manual is talking about an after market DP, not the stock type vacuum secondary 4150.
Old Jul 31, 2005 | 10:01 PM
yellow71's Avatar
yellow71
So if you do have 4 idle screws how do you adjust idle? Go for a drop/rise on each one? My manual clearly shows 4 idle screws one on each corner and my carb has the openings for them.
Can anyone with a stock 71 LT1 look at the and tell me how many idle screws you have.
Thanks again
Neil
Old Jul 31, 2005 | 11:48 PM
b71vette's Avatar
b71vette
Default Yep only 2 were on my 71 LT1 orig Holley
Best way is to use a vacuum gauge when setting idle mixture.
Old Aug 1, 2005 | 12:57 AM
Solid LT1's Avatar
Solid LT1
You will only have adjusting screws on the primary metering block on any factory Holley.
To Missing idle adjusting needles?
