vibration noise at takeoff
Old Jul 31, 2005 | 10:57 PM
strack350's Avatar
strack350
Default vibration noise at takeoff
When i floor my car taking off, or even at half throttle taking off i get a strange vibration noise i cannot pinpoint. sometimes it sounds like its in the transmission area, and other times is sounds like its in the rear of the car somewhere, but always underneath. Are there any areas that are suspectable to vibration like this? Again it only does it on take off, never while moving
Old Jul 31, 2005 | 11:21 PM
pauvil's Avatar
pauvil
front differential bushing?? U-joint?? Tranny mount?? motor mount??
Old Aug 1, 2005 | 12:44 PM
strack350's Avatar
strack350
thanks for the reply, i checked the u-joints, and the diff bushing, and they look fine. I never thought of the tranny mount, I'll check that out now, thanks
Old Aug 1, 2005 | 02:57 PM
rihwoods's Avatar
rihwoods
https://www.tracyperformanceenterpri...diagnosis.html
Important to understand source...many vibration causes...good luck
Old Aug 2, 2005 | 09:25 AM
79blue's Avatar
79blue
Try checking tire balance,Flat spots from setting, if new tires try tire truing(the process when they shave the tires to match each other)
Old Aug 2, 2005 | 08:04 PM
strack350's Avatar
strack350
ok, maybe i should clarify. There is no "felt vibration". just a noise that sounds like something shaking/fretting against something else. I have looked over everything i can think of and cannot find it. its driving me crazy if you have any ideas about what may be loose, or shaking at take off only please let me know
Old Aug 2, 2005 | 11:58 PM
rihwoods's Avatar
rihwoods
Rap your exhaust with a rubber mallet and check hangers..another possibility is the E-brake shoes...
Old Aug 3, 2005 | 08:07 AM
Ybnormal's Avatar
Ybnormal
Check trailing arm bushing (in the front of the trailing arms) to see if they are worn.
YBnormal...drive a vette
To vibration noise at takeoff
