Shorty headers available?
Old Aug 1, 2005 | 10:45 AM
carriljc's Avatar
carriljc
Default Shorty headers available?
I'm going to be needing some new headers for my 68. I was considering going to shorty type headers since I'm tired of my full length units rubbing on the ground.
I'm in no hurry, but I know my full length headers are on the way out and I was considering some with ceramic coating and I thought I'd look for shorties.
Anyone know of a brand or type that will fit?
Old Aug 1, 2005 | 12:50 PM
71SoCal's Avatar
71SoCal
I've got Hedman Shorty Headers on my '71 small block.
I have no complaints with the exception of it's a little tough to get to a couple of the spark plugs. Also, I had to route spark plug wires 1, 3, 2 and 4 down and behind the motor mounts, then across the side of the block.
The thing that I really like about them is how easy they are to remove and then re-install. You don't have to snake a big header down the side of the motor.
Old Aug 1, 2005 | 05:49 PM
Jclgodale3's Avatar
Jclgodale3
Here's mine...no fitment issues at all...
Old Aug 1, 2005 | 07:30 PM
rcread's Avatar
rcread
The bock hugger headers generally don't do a whole lot better than stock exhaust manifolds in dyno testing. They will save some weight though.
Old Aug 1, 2005 | 07:55 PM
Taijutsu's Avatar
Taijutsu
How does having AC change the fit? I'm sure that shorties 1 5/8" fit/flow better w/TFS heads than stk rams horns. I'd like the top end of long tubes but don't want the scraping/grinding over bumps.
Rick
Old Aug 1, 2005 | 08:31 PM
ManFromEagle's Avatar
ManFromEagle
When you use shorties does the stock exhaust bolt right up? What I'm asking is do they mimic the placement of the stock rams horns?
Old Aug 1, 2005 | 10:57 PM
carriljc's Avatar
carriljc
Default part numbers???
Thanks for the info ...do you guys happen to have part numbers?
Old Aug 2, 2005 | 01:50 AM
Z-man's Avatar
Z-man
I wouldn't bet on it - I think you need to custom fit a piece between the new headers and the stock system.
Old Aug 2, 2005 | 10:30 AM
1pfieffer1's Avatar
1pfieffer1
goto
http://www.thermaltechcoatings.com/new_headers.htm
scroll down until you see
"Tri-five Chevy's and Corvette"
they are a 3/4 header that will fit corvettes. They also have block huggers available. Nice people to work with, very helpful via e-mail from their website.
Old Aug 2, 2005 | 03:59 PM
Lotus76's Avatar
Lotus76
I have this set of Dynomax with ceramic coating that I would make you a nice deal on... Let me know if you are interested.
John
To Shorty headers available?
