Fuel Leaks....
Old Aug 3, 2005 | 01:09 AM
more_cc's's Avatar
more_cc's
Default Fuel Leaks....
During an AC rebuild I noticed that I have a fuel leak at the fuel pump... it's one of those where you start fixing a loose nut and end up converting the AC to R134...
Anyway the problem is I can't tell exactly where it's coming from, there's fuel dripping from the two rubber pipes that run from the main fuel lines to the pump but that maybe because they're the lowest point on the pump. There's also fuel on the pipe that runs up to the carb... does anyone have experience with fuel pumps on a 1980 C3 and where they are most likely to leak? And if so what is the best course to remedy this?
Any help would be much appreciated!
Old Aug 3, 2005 | 01:46 AM
Mr Fanuc's Avatar
Mr Fanuc
I notice that you said "pipe up to the carb", are you running a Q-jet carb? I have a ' 77 and while still running the Q-jet had problems with the fuel fitting leaking at the carb. I used Loc-tite thread sealer, not locker, and put an end to the problem. My advice would be to find the highest leak and fix it first, as you said the drip from the bottom hoses may be because they are the lowest point. Hope this helps.
Old Aug 3, 2005 | 03:08 PM
more_cc's's Avatar
more_cc's
Thanks, just out of interest can the fuel pump itself leak? I know it's a sealed unit but I'm wondering if it could be to blame.
Old Aug 3, 2005 | 03:12 PM
fl_rider's Avatar
fl_rider
Default Yes!!
And when it does it leaks into your crankcase.
A little birdy told me. Honest!!
Oil that smells like gas is not cool.
Old Aug 3, 2005 | 03:18 PM
gearheadz's Avatar
gearheadz
If the pump diaphram fails, it will pour out of the pump not leak so I agree it's probably a small leak at the carb fitting or where the rubber attachs to the fittings.
Old Aug 3, 2005 | 05:10 PM
kidneyboy's Avatar
kidneyboy
xactly what happened to my car.
Old Aug 4, 2005 | 01:30 PM
more_cc's's Avatar
more_cc's
Thanks for all your help... a couple more things;
Last night I emptied the tank, took off the rubber hoses that go from the main fuel lines into the pump, disconnected the metal pipe that runs from the fuel pump to the carb. I'm going to replace the rubber pipes and I would like to replace the metal pipe as well.
Now has anyone managed to remove/replace this pipe without removing most of the engine!?!
Also whilst I'm here is it a good idea to replace the gaskets of the fuel pump to the engine block? Or should I just replace the whole fuel pump? I don't really like the idea of draining the tank again!!!
1980 C3 350cu
Old Aug 4, 2005 | 01:57 PM
Garys 68's Avatar
Garys 68
Some pumps (Carters) have a vent hole which will leak gas if the diaphram fails. The rubber diaphrams can also leak out the sides.
Gary
Old Aug 4, 2005 | 04:37 PM
Techno's Avatar
Techno
If you can't find the leak source with your hand try a patch of paper towel. Start high and move down. Simple indicator of where the gas is starting from.
Then you can decide on what needs to be fixed.
It might be blowing out in a fine mist but that should be visable if looked for.
To Fuel Leaks....
