A/C bracket & headers
Old Aug 3, 2005 | 11:30 PM
KillerBee's Avatar
KillerBee
4th Gear
Default A/C bracket & headers
Hey gang
Well I'm still learning about the SB 4 spd 69 Vette, planning on Hooker headers and sidepipes.
I see now that the A/C bracket needs to modified to fit around the header tube.
Is there an after market bracket to fit around the Hooker tube?
Do I just grind the crap out of the original one?
Does this have any effect on car value?
Should I just weld and machine a new one?
Thanks!!
Old Aug 4, 2005 | 10:52 AM
After Shark's Avatar
After Shark
http://www.holley.com/data/Products/Technical/2224-34HKR.pdf
Click on the link above and you can read the instructions for installing the headers. I believe hooker tells you how to modify your existing or sell a different bracket to make the install.
Old Aug 4, 2005 | 11:51 AM
scotty13's Avatar
scotty13
i just ground, welded, and cut on mine. it works like it is supposed to. it was a two piece bracket and now it is one.
Old Aug 4, 2005 | 10:49 PM
GTENIT's Avatar
GTENIT
dont use the factory bracket. go to summit -jegs local parts store they have a bracket for the rear of the ac pump it will fit between the tubes.
heres the part no from summit hok-10926hkr hope this helps
Old Aug 5, 2005 | 12:53 AM
KillerBee's Avatar
KillerBee
4th Gear
Kool, thanks After Shark for the link. Printed it out!!!
Thanks GTENIT for the PN. Got the stuff on it's way now. Woohoo!!!
To A/C bracket & headers
