C3 - front coil spring
a 2-letter code on a tag. Springs were selected at the factory
to set ride height properly. So, they vary in length (stock).
Roughly, they should be about 14 to 14.5 inches uncompressed.
NHvette - what kind of paint is that on your gas tank ?
I couldn't believe how much shorter my 550 springs were than the OE ones that came out.
-dath
-dath
http://www.harborfreight.com/cpi/cta...temnumber=3980
My car had the optional, factory, heavy duty suspension. The springs were the short ones. There is not much danger in using a floor jack. The spring in the top pocket can not go anywhere. Once the lower control arm is raised and the spring seated in the lower pocket, I don't see how it can come out. With the longer softer springs, that may be different. I can only comment on my car with my springs. Like most other jobs, use a little common sense. If something doesn't seem right or may seem to be dangerous, then take the necessary precautions.
The jack is fine, although a single ended threaded rod compressor
makes installing the stock springs easier.
Folks have gotten these to work fine, but I would use half of this
with the rod pulling up to the shock mount hole. Actually, I'd probably make my own.
http://www.jcwhitney.com/autoparts/P...g%20compressor
I usually leave the shock bolted in the bottom until the spring
is released of pressure (top disconnected). This keeps the bottom
of the spring secure, while the big pocket up top keeps the top in line.
Unless the jack slips off the control arm, the springs aren't going to fly out.
Still, always stand to the side when lowering.
I recall the 460 replacements run about 12 1/2 inches long.
Unless going for NCRS points, 460 or 550 springs are the way to go.
Any ideas on how much clearance required under lower a-arm before I start to lower it ?
Gary
no incident
