Tripometer not working
Old Aug 4, 2005 | 02:20 PM
Tombags's Avatar
Tombags
Default Tripometer not working
Hi,
My tripometer doesn't work on my 1974. My odometer works fine. I can reset the tripometer and the numbers will turn however they will not turn with the odometer. Any ideas????
Tom
Old Aug 4, 2005 | 02:36 PM
danboback's Avatar
danboback
I have the same problem....ttt
Old Aug 4, 2005 | 03:27 PM
Buzzardz_vette's Avatar
Buzzardz_vette
Same problem here!
Old Aug 4, 2005 | 03:28 PM
Buzzardz_vette
Same problem here! And I replaced the plastic gear, but still does not work.
Old Aug 4, 2005 | 03:35 PM
big69's Avatar
big69
My numbers go around but the reset doesn't work.
Old Aug 4, 2005 | 03:46 PM
LYLE's Avatar
LYLE
Pull down on the **** and they may start to turn. If that dosen't work take the cable loose from the dash and see what happens as it may be in a bind. Some spray lube may help also.
Old Aug 5, 2005 | 02:15 AM
chris75stingray's Avatar
chris75stingray
you push the **** up and spin it to reset. then you need to pull the **** all the way back down for it to work.
To Tripometer not working
