Spal dual fan wireing question.
Old Aug 4, 2005 | 05:55 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Default Spal dual fan wireing question.
Can i use the stock sensor between the #1 &#3 cyl. to pull in
the relay for one of the fan,s. I was just going to tie into that
single green wire. The gray wire from the relay go,s to it and
grounds out it complete the circut. Will that screw up the temp.
gage reading. Thanks,
Old Aug 4, 2005 | 08:21 PM
The Green Hornet
Come on people now, smile on your brother,
Old Aug 4, 2005 | 08:34 PM
Jack71's Avatar
Jack71
Isn't that a sending unit to the gauge? I don't think it is the same thing as the thermostat type to turn your fans on/off.
You should mount the unit that comes w/ the fans in the manifold or water pump.
Old Aug 4, 2005 | 08:39 PM
The Green Hornet
Problem is i didn't get one, contacted the vendor & they are sending me one, but i just wanted to get it working until it comes.
Old Aug 4, 2005 | 08:45 PM
SteveG75's Avatar
SteveG75
Will NOT work. Sorry.
The relays need an on off switch. The factory temp sensor provides a gradual resistance for the gauge.
Old Aug 4, 2005 | 08:50 PM
The Green Hornet
Dang, guess i;ll run the wire to ground with a toggle switch.
Old Aug 4, 2005 | 09:10 PM
bruced267's Avatar
bruced267
If you got a controller from Dewitt they say it use the stock sending for the gauge, and you can controll the on off points, and request for a/c . So where did you get the fan?
Old Aug 4, 2005 | 10:12 PM
The Green Hornet
Alu. rad & fans from Dewitt's
To Spal dual fan wireing question.
