Lowering Ideas
Old Aug 4, 2005 | 09:01 PM
66CorvetteCoupe's Avatar
66CorvetteCoupe
Default Lowering Ideas
Just finished the 68 BB Coupe including a complete front end rebuild with the 550# VBP springs. It was my understanding these springs should lower the front approx 1". This is a alum. headed car which are much lighter than their cast iron counter parts. This car has the L-88 flares so I have plenty of room to come down 2"+/-. Whats everyone's experience with these springs, did they lower the front enough to tell the difference? I have checked to be sure they seated in the perches so I assume they are in correct. What about trimming these springs a coil to get it down. Open for suggestions here. Thanks for everyones input you guys have helped me to no end with minor problems. The turn signal switch problem got corrected after my post, Shee-Mar out of Colo. sent me the replacement switch thanks to the Forum and the help I received from you guys.
Old Aug 4, 2005 | 09:43 PM
kona's Avatar
kona
When you redid your front end did you tighten everything up with weight on it? If not loosen everything till hand tight drive around the block and re tighten with the car on the ground or on ramps.
Kona
Old Aug 5, 2005 | 03:43 AM
dath's Avatar
dath
On my '74 small block I put the same 550# coils on and didn't notice much difference. Unfortunately I was too stupid to measure before and after, but visually, I didn't notice much if any difference between the stock ones and these. Of course with my factory original stock springs, who knows, they may be saggy after that many years. . .
Old Aug 5, 2005 | 05:37 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Do a search on coils, front end too high, etc. There's been a ton of posts.
Old Aug 5, 2005 | 08:13 AM
1979L82's Avatar
1979L82
Default lowered mine
I finished this change about 3 months ago and recently had an opportunity to measure after the 4 wheel alignment.
I have a '79 4 speed car w/air if it makes a difference, but removed/kept off the AIR pump after the engine was rebuilt. Like you I installed the 550 lb. springs replacing the original factory L82 performance suspension.
Now that things have settled, the lower edge/lip of the wheel opening is 1" away from the tire. It was about 1.5" before. I am running the recommended P255/60/R15 on original factory aluminum rims. I also replaced the A-arm bushings, where more or less rebuilt the entire front suspension.
At one point I was going to cut off one coil. I am glad I didn't with my current setup.
Did you make certain that the end of the coil was located in the lower A-arm pocket correctly?
Old Aug 5, 2005 | 08:15 AM
BDVT69's Avatar
BDVT69
Kona
I did a complete body off resto of my 69 vert and put the BB springs in the front. I did not tighten the A arm bolts and took it into the paint/body shop in May. The guys at the shop move my car around from time to time and I have notice just from the moving and sitting for 3 months that the car has lowered almost 3/4 inch. Once I get it back from the shop I will drive it around the block and then tighten the A arm bolts.
Old Aug 5, 2005 | 09:11 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Here's mine with the 460lbs springs:
and with 550lbs springs - see a difference ??
Old Aug 5, 2005 | 06:10 PM
66CorvetteCoupe
Default 550 # Springs
Well to date I have not totally tightened the bushing bolts, they were finger tight until I put it on the ground. After lowering the car to the ground and moving the car forward and backward a few times I snugged the bolts with a wrench. I plan on a cpl of hundred miles before I torque the bushings, I used all Poly bushings so they are a little stiffer than the rubber type. I am going to double check the springs again to assure thay are seated properly, I checked that several times while the car was elevated on the lift. Thanks for all the suggestions I will follow up in a day or two. "RED-BAD" Thats sits good the way I wanted my 68 to sit.
Old Aug 5, 2005 | 06:25 PM
7T3C3TTZ07's Avatar
7T3C3TTZ07
I measured all the fender openings and 4 location on frame to garage floor. According to a CF thread, cutting 1/2 coil from a 460# coil will lower the front by 1" and the 550# spring (not cut) will lower the front by 1/2." Based on a the reco of a CF thread, I cut 1/2 coil from the VBP 550# springs in order to lower the front by 1.5" On my ride, it turned out that the front was lowered by 1/2". I assume that without the cut it would have matched the ride height of the original FE7 spring. I'll drive it a bit and trim out 1/2 coil. For info, my front fender opening (measured through center of wheel perpendicular to floor, started at 28.5" and went to 28.0. I am after 27" These dimensions vary according to body mounts, so I also measures at the frame locations listed in the assembly manual.
To Lowering Ideas
