Ac/ Heater Problem
Old Aug 5, 2005 | 12:11 PM
bigdave73's Avatar
bigdave73
5th Gear
Default Ac/ Heater Problem
I Need Help. I Have A 73 Small Block And My A/c Will Not Work On High And Neither Will The Heater. I Replaced The High Speed Relay And The Blower Motor. Problem Wasn't Fixed. Any Help Would Be Appreciated...
Old Aug 5, 2005 | 12:38 PM
NeverFinished's Avatar
NeverFinished
I ran into the same thing. Replaced the same stuff without fixing the problem. Later, by accident, I noticed a wire was not connected on the wiper relay connector near the distributor. On mine there is a three wire connector and a two wire connector. Apparently, when I tried to plug in the two wire connector the first time I only connected one of the two wires. After I reconnected it properly, the high speed fan worked fine.
Old Aug 5, 2005 | 02:34 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
Have you checked the inline fuse?
The high blower has a inline fuse that is seperate from the normal blower fuse under the dash. There should be a heavy gauge orange wire coming off of your horn relay and routed back to the firewall and across to the high blower relay. The fuse will be about 6" from the horn relay.
Just in case you didn't know, the horn relay is mounted inside the driver's side fender beside the washer bottle.
Old Aug 5, 2005 | 07:34 PM
bigdave73's Avatar
bigdave73
5th Gear
ALL I HAVE TO SAY IS YOU GUYS ROCK!!!!! I SPENT $50.00 AND ALL KINDS OFTIME GETTIN THAT BLOWER MOTOR OUT WHEN IT WAS A $.15 FUSE....... KILLIN ME. I SHOULD HAVE KNOWN TO ASK FIRST. OH AND THE WIPER RELAY WAS A GOOD FIX SINCE I CHANGED THE WIPER MOTOR LAST WEEK. THE WIRES WERE CONNECTED CORRECTLY AND AT LEAST THAT MOTOR WAS REALLY BAD.. THANKS AGAIN.
To Ac/ Heater Problem
