Is there anyway to....
Old Aug 5, 2005 | 01:00 AM
more_cc's's Avatar
more_cc's
Default Is there anyway to....
The previous owner of our 1980 C3 did a bad job of fitting the turn signal lever because it doesn't click left and the high beam doesn't work. Is there anyway to get to this without removing the entire steering column? I've got some instructions already on getting to the switch but nothing to describe how to just get to the lever?
I've got the steering wheel off all the way to the turn switch but I'm at a loss of how to get below this?
I can't seem to find any instructions on removing the ignition lock housing or at least getting to the turn signal lever mounting.
Any ideas?
Thanks in advance!
Old Aug 5, 2005 | 06:09 PM
BigBlockk's Avatar
BigBlockk
You may want to get in touch with Jim Shea. He is the steering system guru 'round here.
BigBlockk
Later.....
