Rotating air cleaner
Old Aug 6, 2005 | 09:58 PM
foundvettelifeisgood's Avatar
Default Rotating air cleaner
This air cleaner likes to rotate. Any ideas on how to keep it straight? Maybe a thin rubber gasket on the carb? Every time I lift the hood after driving, it's on a 45 degree angle.
Old Aug 6, 2005 | 11:03 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Can't help you with the air cleaner, but I would like to see your valve covers up close because I am thinking about getting new ones.
Old Aug 6, 2005 | 11:21 PM
Retro78's Avatar
Retro78
And the air cleaner also...where did you get that?
Old Aug 7, 2005 | 07:44 AM
Billet Specialties makes them. You can get them from Summit. They are high quality beautiful pieces, although I did have to return a couple air cleaners to get one with a perfect finish.
I got the tall version of the valve covers for looks, which required a different alternator bracket and longer belt. The air cleaner will test the limits of your hood clearance. No problem with the L-88 hood.
Any help with the rotation issue would be appreciated...
Old Aug 7, 2005 | 08:24 AM
Ganey's Avatar
Ganey
Originally Posted by foundvettelifeisgood
This air cleaner likes to rotate. Any ideas on how to keep it straight? Maybe a thin rubber gasket on the carb? ...
Yes a carb to cleaner gasket would help. A locating pin(s) like a screw could be installed in base from the bottom.
Looks good.
Old Aug 7, 2005 | 04:05 PM
fugawi's Avatar
fugawi
try tightening the bolt some more.. if that don't work, maybe the bolt is bottoming out. take a quarter inch off bolt...
To Rotating air cleaner
