Tach problems.
Old Aug 7, 2005 | 10:32 AM
santovette's Avatar
santovette
Cruising
Default Tach problems.
I'm trying to get all the instrumants to working in my 80 vette. What color wire goes from the distrib to the tach??
Old Aug 7, 2005 | 06:41 PM
wombvette's Avatar
wombvette
Gray, should also have a filter in line.
Old Aug 7, 2005 | 08:43 PM
kona's Avatar
kona
On my 80 it is a tan wire.
Kona
Old Aug 7, 2005 | 10:58 PM
bams12's Avatar
bams12
I am listening in on this thread. I have replaced the printed circuit board on my tach , the printed circuit that the wiring harness plugs into and the tach filter. Still no working tach. I have a signal from my distributor as read on the tach/ dwell meter. Brent
Old Aug 7, 2005 | 11:03 PM
big_G's Avatar
big_G
FYI, I just installed a tach p.c. board from E****rs, no good. I talked to a "Major" gauge rebuilder we use, he says the ones from e****rs, don't work, and to use the ones that Corvette C****al sells....I will try that next..
Old Aug 7, 2005 | 11:17 PM
bams12's Avatar
bams12
Imagine that, I checked through my stack of bill and my tach board is from ecklers. I wish I had that info prior to the removal of the dash pod 3 times and all the associated headaches. Thanks for the heads up. Ecklers is going to be getting an email. Brent
Old Aug 7, 2005 | 11:28 PM
Empatho's Avatar
Empatho
my tach doesnt work either so I just ordered one of this
Old Aug 8, 2005 | 08:22 PM
santovette's Avatar
santovette
Cruising
I got the tach that came in the car working but at 70 miles per hour it registers 3500 rpms with the sun tach it registers 2500.
To Tach problems.
