Hello all im hoping somone can help. I have a 1973 L48 and im having probs with it.When i turn on the lights the two right side parking lights are not working, also the right side turn sig is not working...any thought's
Is it the front and rear side marker lights?
Or the front side marker light and the front parking light?
I suspect it is the front side marker and front parking lights. If so, check the bulbs first.
If the bulbs are OK it is most likely the ground.
If you can't find the ground let me know and I will see if I can get a pic for you.
Good luck.
