Ignition
Old Aug 7, 2005 | 10:25 PM
Matt 1980 L-82's Avatar
Matt 1980 L-82
Default Ignition
Can someone please explain to me the difference between points and HEI ignition systems, and tell me which one a 1980 L-82 Corvette would have?
Old Aug 7, 2005 | 10:37 PM
big_G's Avatar
big_G
Points are crude mechanical/electrical design about 100 years old, prone to adjustment and wear issues. HEI, High Energy Ignition is an electronic system, much more reliable, with no periodic adjustments. It delivers a higher voltage spark, and the coil is integrated into the distributor cap. Yours should have HEI, available since 1975. HEI can be identified by a large cap, with no seperate ignition coil.
Old Aug 7, 2005 | 10:55 PM
Matt 1980 L-82
Thanks a lot, that was fast.
Old Aug 7, 2005 | 10:58 PM
big_G's Avatar
big_G
YW
Old Aug 8, 2005 | 12:14 AM
rcread's Avatar
rcread
Coincidently, I am often described as cude, about 100 years old and prone to adjustment and wear issues.
To Ignition
