Sealed vs. vented gas cap
Old Aug 8, 2005 | 08:40 PM
foundvettelifeisgood's Avatar
Default Sealed vs. vented gas cap
Zip sells both. Can I go with a sealed cap in my 72, or will I have vapor lock type issues?
Old Aug 8, 2005 | 08:51 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
This is what I have found with my vette. I bought a sealed gas tank lid for mine when I first got the car. All was fine with the car. After I rebuilt the motor, I put on an Edlebrock Fuel pump and eliminated the return line to the tank. Now, if I fill the tank and run most of it out in one day, when I loosen the gas cap, I can hear the tank sucking in air.
Deducing from that, I would think that vented would be the way to go. I am still running the non vented style on mine though.
Maybe someone else that knows a little more will chime in on this one.
Old Aug 8, 2005 | 09:03 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
72's originally came with a sealed cap.
Old Aug 8, 2005 | 09:09 PM
StickShiftCorvette's Avatar
StickShiftCorvette
If you run a non vented cap and use a fuel return line your tank will pressurize. The '69 owner's manual warned you to open the cap slowly to relieve any pressure. If you do not run a return line you could draw a vacuum in the tank, although when I ran this way I never saw any sign of that happening.
You may smell gas if you use a vented cap.
Old Aug 8, 2005 | 09:27 PM
Gordonm's Avatar
Gordonm
I am running a non vented cap and have no return line. I have never had any problems running this way. My car did not come with a return line. It did have the charcol cannister which I have eliminated. I just plugged the line from the tank.
Old Aug 8, 2005 | 10:32 PM
Techno's Avatar
Techno
But hes got a 72 and should have a sealed?
My 68 wouldn't matter sealed or vented since the overflow would let the air in anyway. I found this out from too much gas and too much acceleration
Old Aug 9, 2005 | 05:48 AM
Gordonm's Avatar
Gordonm
My cap is original on my 72 and it is non vented.
Old Aug 9, 2005 | 06:51 AM
Graemeinvette's Avatar
Graemeinvette
During the rebuild of my 70 I found I had the tank from a 77! Which probably accounted for all the Bubba rear end fibre glass repairs, the kink in the chassis etc.
Old Aug 9, 2005 | 10:00 AM
NHvette's Avatar
NHvette
Unless the 72 is an LT-1, then it should have EEC (vent to canister)
on the drivers side of the tank. You should be able to see this,
looking up under the fender. With the vent (properly working),
it should use a sealed cap. Without the vent, use a vented cap.
I chose to block my vent line at the tank and use a vented cap.
OK - looking further, maybe even 72 LT-1s had EEC system.
Yup - just looked it up - all 71,72 have EEC system.
The LT-1s do not have a return fuel line from the pump.
Old Aug 9, 2005 | 10:38 AM
GDaina's Avatar
GDaina
You HAVE to use the gas cap designed for your gas tank....use of wrong cap will result in disasterous effects....ask me how I know...
Old Aug 9, 2005 | 10:47 AM
DonBecker's Avatar
DonBecker
I'm having bad stall issues, 76, L-48 w/vented cap...GDaina, more info please?
Old Aug 9, 2005 | 10:52 AM
GDaina's Avatar
GDaina
My 68 requires a vented cap...I put on a non-vented locking cap..within 100 miles, the stock mechanical pump sucked all the air out of the tank and collapsed it...yup...the metal tank looked like a balloon with all the air sucked out..
Old Aug 9, 2005 | 10:59 AM
DonBecker's Avatar
DonBecker
Cool. But how would putting a vented cap on an originally non-vented cap car cause an issue? Would it?
Old Aug 9, 2005 | 11:23 AM
GDaina's Avatar
GDaina
I don't have an answer for that....maybe fuel delivery problems...maybe gasoline vapors escape and cause catostrophic results in case of a spark...sparks can be caused by number of ways...static...or other...in that case...KABOOOOM
Old Aug 9, 2005 | 04:02 PM
LemansBlue68's Avatar
LemansBlue68
The non-vented caps were added as an evaporative emissions HC control. Cars with non-vented caps used a charcoal cannister to absorb the fuel vapors. The vapors are purged after the engine is started and the fumes burned similar to how the PCV system works. A solenoid valve is usually used to purge the vapors.
Using a vented cap on a car that was intended for a non-vented cap won't hurt anything other than you will smell gasoline vapors occasionally. It can also be a quick fix for a faulty purge system.
Putting a non-vented cap on a car that was meant for a vented cap can problems such as fuel starvation or in GDAINA's case, worse.
Old Aug 10, 2005 | 12:06 AM
68/70Vette's Avatar
68/70Vette
Put on a vented cap. This will make everything easier for fuel flow. There may be some esoteric issues with gasoline vapor escaping into the air, but I think if you do this the world will not be really effected.
I have vented caps on my 68 and 70 and as far as I know there's been no adverse effect on the environment.
Old Aug 10, 2005 | 04:38 AM
hunt4cleanair's Avatar
hunt4cleanair
Fuel vapor emits hydrocarbon emissions and do contribute to environmental pollution. An entire industry grew up to corral automotive emission pollution with GM behind it...that was Ed Cole who ordered the GM fleet to be ready for unleaded fuel by 75 which brought about charcoal cannisters, vapor/separator valves, leaded fuel restrictor plates and the non-vented gas cap.
Old Aug 10, 2005 | 08:10 AM
GDaina's Avatar
GDaina
fuel vapor extremely flammable...how many times have I've seen on the news a story about a car catching on fire as the driver is filling the gas tank...static electricity igniting the fuel vapors.
Not something I want to mess with...use the correct cap for the system the cap is designed for.
Old Aug 10, 2005 | 08:16 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
my '68 originally came with a vented cap which I'm still using.. However, I changed my gas tank and went with a tank that doesn't have a return-line hook up... Don't know if the vented cap is the right cap for that setup, but I believe it is because I've never had any issues...
To Sealed vs. vented gas cap
