82 back drops
Aug 9, 2005 | 02:48 PM
82 back drops
I have a 1982 corvette that when the shifter is move to a forward gear the back end of the car drops down about 2". Is this normal
Aug 9, 2005 | 02:56 PM
St. Jude Donor '08
common on all vettes. Can help it a bit by replacing the front diff bushings and the crossmember bushings.
Aug 9, 2005 | 03:34 PM
Quote:
Aug 10, 2005 | 12:20 AM
How hard is it to replace the crossmember bushings?
Do you have to lift the body?
Aug 10, 2005 | 10:55 AM
I figured it was just the car getting ready to run like a sprinter in the starting blocks...
Aug 10, 2005 | 11:36 AM
St. Jude Donor '08
Don't have to life the body, but you do have pull your half shafts and anything connected to the differnetial. Front diff bushing you can do on the car, but its a PITA. Gotta pull driveshaft and be really nimble.
Aug 10, 2005 | 03:24 PM
Aug 10, 2005 | 04:23 PM
St. Jude Donor '05-'06-'07-'08
My 82 does that also(800)rpm, put it in reverse, it stads up
