BB bypass hose
Old Aug 10, 2005 | 05:23 AM
61Rat's Avatar
61Rat
Default BB bypass hose
Can anyone tell me if the short hose that runs from the water pump to the intake on a big block can be plugged off? I seem to have noticed that small block cars have a plug in this location, Thanks, John
Old Aug 10, 2005 | 08:05 AM
GDaina's Avatar
GDaina
Yes it can, but am running one on mine...I don't know if there are any ramifications with the removal of the hose.
Old Aug 10, 2005 | 08:52 AM
bigvette1's Avatar
bigvette1
To my knowledge the hose is a bypass to allow coolant to flow from the engine to the water pump and circulate until the t-stat opens. Unless you use one of the partially open t-stats or drill holes in the t-stat to allow flow before fully open there will be pretty heavy pressure built up in the block. Stewart water pumps has some articles on this.
To BB bypass hose
