window
Old Aug 10, 2005 | 10:02 PM
Empatho's Avatar
Empatho
Default window
I have power windows in my 78 vette and they never worked and I want to fix them, I noticed that the Previous owner cut the wires from the AC and heater control unit and the ones coming from the seat belts if those are removed do they affect the working condition of the power windows If they do do I have to re wire the car
Old Aug 10, 2005 | 10:04 PM
Empatho's Avatar
Empatho
I was thinking of removing the power windows and getting manual windows is it easy to do
Old Aug 10, 2005 | 10:23 PM
Empatho's Avatar
Empatho
Ok I dont want manual windows I want to stay with the power windows but they dont work and they are making me
Old Aug 10, 2005 | 10:44 PM
goinbroke's Avatar
goinbroke
Could be nothing more than a bad relay or circuit breaker. Here is a site with some good electrical info including some drawings of where various components are located. http://www.corvetteforum.net/c3/tune...l/index6.shtml
Click on "power windows". There may also be some help there on your seatbelts and AC/heater control.
Old Aug 11, 2005 | 12:00 AM
Empatho's Avatar
Empatho
thanks for the link to the site it's great for information
Old Aug 11, 2005 | 12:36 AM
Empatho's Avatar
Empatho
I think the problem is the ING - to gauges fuse because the lights to my gauges don't work I"m going to check tomorrow
Thank You Goinbroke
Old Aug 11, 2005 | 12:58 PM
72GACRZR's Avatar
72GACRZR
If you do a search you will find lots of threads on power windows. One problem that slows them down is dried and gunky grease, that requires you to remove the door panel and pull out all the channels and clean them up. Check the past threads.
Old Aug 11, 2005 | 01:28 PM
Empatho's Avatar
Empatho
I was working on it, and it started to rain
Old Aug 11, 2005 | 04:40 PM
Empatho's Avatar
Empatho
Thanks guys for the help I fixed the windows
To window
