Boomin Stereo Kills Vette?
Old Aug 11, 2005 | 12:29 AM
ferndog4's Avatar
ferndog4
Default Boomin Stereo Kills Vette?
Not sure what the problem is? Apparently if I run the car with the stereo loudly at idle the car wants to stall. Not sure what cuases this? Do i need a more powerfull altenator? Bad regulator? I have had a few issue with my altenator recently. It wasnt charging so I had it rebuilt, now charges fine but now I encounter this. Perhaps its it too much load? Any help is appreciated. BTW, its a 1980 vette with 1985 vette altenator, idle @ 850rpm.
Thanks!
Old Aug 11, 2005 | 12:44 AM
C3nMe's Avatar
C3nMe
What is the voltage across the battery when this thing is in a "near stall" condition? If the voltage gets too low, you'll have inadequate spark and that can lead to missing.
Load in the alternator could increase the drag it creates on the engine, but I don't suspect that it would stall it out (unless the A/C kicked on at the same time, further loading the engine)
Is this an auto? If so, are you in drive when this problem occurs, or neutral?
My first guess is you're seeing an undervolt situation, an that doesn't necessarily have to mean a bad alternator or regulator -- they don't put out 100 amps at idle, after all.
Brian.
Old Aug 11, 2005 | 02:15 AM
ferndog4's Avatar
ferndog4
thanks for the help! Its a four speed car. A/C is non-functioning. I tried turning on the head lights and the car really doesnt like that with the stereo going.
Old Aug 11, 2005 | 04:50 AM
Unforgiven1's Avatar
Unforgiven1
A large capacitor and or a larger battery to manage the load from the amp could help. Maybe raise the idle a little bit as well. Most GM alternators don't have much output at 850. It also couldn't hurt to upgrade the alternator output wire to the battery. I can't remember the size of the factory one but I know I upgraded mine to 8 gauge when I did the LT1 swap.
Old Aug 11, 2005 | 07:51 AM
Boofers's Avatar
Boofers
Right on! You must have a wicked stereo!
I have heard of guys replacing thier alternator pulley with a smaller one to get the alternator to spin faster.
Some automotive electrical shops can upgrade your alt for more power at less RPM. I have also heard of kits you can buy to do this yourself.
Old Aug 11, 2005 | 08:03 AM
Jack71's Avatar
Jack71
I had a problem where my amp was cutting due to an under charge condition. I replaced my alt with a 100amp unit and that cured my problem.
Do you know how much power the stereo is drawing? I'm guessing its an aftermarket setup.
Old Aug 11, 2005 | 08:47 AM
fl_rider's Avatar
fl_rider
Just imagine what its doing to your ears...
Personally I'd rather hear the engine.
Old Aug 11, 2005 | 08:52 AM
GDaina's Avatar
GDaina
I agree with what was said....the alternator can't keep up with the stereo's usage. Update to a 100 amp unit and your problems are over...in fact there is a thread about updating the alternator...can buy a new one or get the kit and do it yourself.
Old Aug 11, 2005 | 09:02 AM
red topless gator's Avatar
red topless gator
Old Aug 11, 2005 | 10:27 AM
72LS1Vette's Avatar
72LS1Vette
I'm guessing that you have a big subwoofer or 2 in you system and when you say playing 'loud' you have enough bass to be heard blocks away. You probably need to add at least 1 1-Farad capacitor to the electrical system. Loud low frequency impulses draw tremendous amounts of power from the amplifier and the capacitor will provide extra power to help even out the peaks. You probably need a higher power alternator also.
Rick B.
Old Aug 11, 2005 | 11:45 AM
jlaw68's Avatar
jlaw68
its that COUNTRY MUSIC thats making the car stall, not the stereo
Old Aug 11, 2005 | 12:01 PM
MsVetteMan's Avatar
MsVetteMan
I prefer to listen to my car when I drive it. Being almost 25 yrs old, she make a lot of weird noises............But the true dual exhaust is all the sweet tunes I need to hear!
Old Aug 11, 2005 | 12:49 PM
ferndog4's Avatar
ferndog4
Trust me I love to hear my dual 2.5 exhuast and my solid cam clatter away but when on a busy freeway your hearing all the other cars/trucks too. So in comes the stereo, I never thougt it was too loud, just a tiny, single 8" JL Audio sub and some component speakers, and two amps two support them.
Now when comming to a stop on the freeway cuz of traffic the last thing i need is the car stalling out. Way embarassing. Justifies why the Tree Huggers want to get rid of old cars in california. I think i will try the capacitor, $40 on ebay and look into higher output Alt, and increasing my idle, in otherwords, all the above.
thanks!
To Boomin Stereo Kills Vette?
