Trick-Flow top end kits from Summit
Right now, I have about $2,000-$2,250 to spend on my engine and i'm thinking about using one of the trick-flow top end kits from summit. Click on the link below to see what I'm talking about.
http://www.summitracing.com/catalogs...yaug/135f.html
I'm eyeballing the "pro street engine kit" (the 445 hp, 405 tq) since I'm planning on keeping my 350 a 350. If you read the info on the other kits, even though they have higher numbers, they are tested on 383s while the one I'm looking at was tested on a 350.
If I need to, I plan on buying new pistons but i want to keep my compression ratio around 10.4. I also have my old Performer RPM intake manifold and a holley 750 cfm carb that i intend to put back onto my engine.
I would upgrade to a 383 stroker, but that is a little out of my budget at the moment.
So, my question is what do all of you experts on the forum think of this setup? Can I find something better for this ammount of money? Should I keep my Performer RPG manifold or upgrade it for an Edelbrock Air Gap Manifold (I'm not sure about clearance under my hood with this manifold)? Anything else I'm forgetting or not thinking about??
I'm new to all of this engine stuff and I don't really have a clue what I'm doing.
Thanks, again, in advance
Victor
BigBlockk
Later.....
I have a TH350 auto transmission and, as part of my whole build-up, I was intending to instal a shift-kit.
Any recomendations as far as transmission is concerned?
edit:
also, can a TH350 handle that much torque?
Small blocks that turn need gear to get going. I would say at least a 3000 stall and 3.55-3.73 gears (if you have 3.36 you can manage, but 3.08 or less
) Keep your intake and carb...You don't have to change pistons unless you want 2 or the motor is worn. Then do a full rebuild with bearing and rings also. The 64cc heads will increase your compression anyway.
hell you can almost buy a new crate motor with 2500.00
i sure like it!
here's a before/after vid i made
http://www.putfile.com/media.php?n=before-after
here's a idle vid i made back when i first got it going.
http://www.putfile.com/media.php?n=Movie_000274
one more thing, with a edilbrock carb my stock hood didnt close so i got a high rise hood for it....after i got a holley 750dp and holley power shot aircleaner...wa la... stock hood fit's now with room to spare.
Summit part # HLY-300-503-1
$1429.95
Brett
I can't believe I set myself up for that
Thanks for the info (and videos) everyone. I could listen to that engine idle all day!!
I definately have more to digest before I make a final decision
Brett
Another way is to check on board here for a GOOD machine shop in your area. Can buy 383 stroker 5140 steel crank from PAW for about 550.00. New KB Hyper pistons with ring 300.00. I would go with ARP main studs for main caps. Connecting rods need to be refurbished, block blueprinted, assamblely balanced and short block assambled. Depends where you are but figure about 1000.00 for machine shop. Had 383 done by Westside Perf. in Houston for less but brought them new rods to use. In heads bigger is not always better. Was going to use a motown 220 head on my 383 but intake runners are to big for the motor. The tourque with the bigger intake runner would be less then a runner of about 190 cc. World heads has an article on their web site about this. lots of very good tech threads on here. Read them and ask questions about members engine combos. My Motown heads will have to wait for a 427 buildup. If you go 383 route IMHO you will get more bang for the buck, houstonvett
