Trouble with Cruise control
Old Aug 11, 2005 | 10:27 PM
Gary B.'s Avatar
Gary B.
Default Trouble with Cruise control
The CC on my 1979 corvette has starting to act up. When you engage it the car will start to speed up the after approx 7 mph it will act like it is disengaged then it will start all over again. The cc was working on the car up to two weeks ago. I have traced all of the hoses and electrical wires and every thing seems to be hooked up. Any advice would be greatly appreciated. Thanks Gary B.
Old Aug 11, 2005 | 11:00 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
It might be a number of things, mine did the same once and I found if I held in my cc button it stayed ingaged, so I replaced the complete lever control. problem gone. I'm sure you will get a few more suggestion also.
Old Aug 12, 2005 | 09:36 AM
Crash80's Avatar
Crash80
Seems that I remember that TheoUK is very familiar with the cruise control in the Vette. I would send him a PM and see if he can send you the info. on the different components and what might be causing your problem. I tried to find the info that he has provided in the past but could not locate it.
Here is his public profile page so you can e-mail or PM him.
http://forums.corvetteforum.com/member.php?u=47767
Or you can go here and look under the technical header and then click the cruise control link. It will show you all sorts of stuff.
http://iotech.no/corvette/index.htm
Old Aug 12, 2005 | 11:09 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Mine did the same thing as well...changed the lever & my problem was solved.
To Trouble with Cruise control
