Electronics ?
Old Aug 15, 2005 | 08:29 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Electronics ?
I have a electric water pump on my 454. I would like to build a relay or something with about a 5 second delay before the pump is "energized" -from the time I turn the key on to the time the pump comes on (don't want it taking amps while the engine is cranking). What would I need to build something like that?
Old Aug 15, 2005 | 09:07 AM
Techno's Avatar
Techno
A 555 timer chip will do it with very little componants. Just do a search on 555 timers.
You could also hook it up to an oil pressure switch. It might turn on during cranking if your engine is a bit slow to start.
Once oil pressure is present the water pump is powered. It might give you the delay you want without much building stuff.
Old Aug 15, 2005 | 09:36 AM
Hvymtlc5's Avatar
Hvymtlc5
That 555 chip uses 5 volts. I didn't do well in basic electronics - is there anything I can buy off the shelf already built to perform this function?
Old Aug 15, 2005 | 10:03 AM
markdtn's Avatar
markdtn
Just use a relay. Use a ground and the starter signal for the switch side. Ignition power to the other side and then to the pump. Hook it up normally closed. Power to the pump when ignition is on, but not cranking.
Old Aug 15, 2005 | 10:08 AM
Hvymtlc5's Avatar
Hvymtlc5
Sounds like a workable approach - no power to the relay with key in crank position (as I understand it). Are these the normal relays that are used with fog lights or high power horns?
Old Aug 15, 2005 | 12:16 PM
markdtn's Avatar
markdtn
On a normal "Bosch" relay like driving lights or whatever you have 5 terminals. If you look on the side there is a diagram. 2 terminals correspond to a squiggly thing. That is the switch circuit. Put ground to one side and cranking voltage on the other, might use the yellow wire from the starter if your car was originally points. The other 3 terminals correspond to supply and normally open and normally closed. Hook ignition switched power to the supply post and power to the pump to the normally closed port (the one the line in the diagram is laying on). If you have ignition power and are not cranking, you will power the pump. While cranking, the relay will energize and take away power from the pump.
markdtn's Avatar
markdtn
Make sure the relay is rated high enough amp-wise enough to run your pump.
Old Aug 15, 2005 | 01:55 PM
Hvymtlc5's Avatar
Hvymtlc5
Exactly what I was looking for. Thanks
To Electronics ?
