Vacuum – help a retard out…
Separated all forms of vacuum use (tranny, brake booster, “T” at back of manifold, ALL of them)
Timing OK
Changed carb and intake gaskets (no visual cracks while apart – didn’t remove heat shield)
Changed power valve (1.5 year old holley)
Compression good
Sprayed carb cleaner all over while running
Have it down to hole somewhere in my relatively new Holley, hole/crack in intake, or something I am absolutely missing…
Can I have a cracked head on the intake side and lose vacuum?
Discuss………….
initital should be around ten or so maybe more....
I preferr running vacuum advance straight off manifold vacuum...gives much better idle charactoristics that way....
and good for about another ten+ points on vacuum readings...
GENE
Come to think of it, that is *REALLY* bad. At best that is 4.6 mpg. Crap, something else must be wrong too! Damn carb seems right on too.
the car has always run pretty good then started to run a little rough, so I went through the usual tune up stuff, plugs, wires, cap, and rotor...same roughness...
ran compression, all good (for an old worn out engine), checked vacuum, 5 inches - has run 11 or 12 in the past at idle so I am assuming that the roughness and the lack of vacuum are connected somehow.....I'm beginning to think that my intake could be cracked, even though I've never seen one do so...just can't think of much else that would lose that much vacuum since I've disconnected everything, changed intake gaskets, and changed carbs - even pulled the T out of the back of the intake just to eliminate one more thing..???
with the cats, A/C, smog pump...etc..that stuff is for girls..
Roger
Roger
have mine off now - second time this week. put a straight edge on the head side of the intake and it's slightly warped so I have a new one gonna be here friday...we'll see..
